Actually, my mistake, I thought we were talking about D4 on the tap switcher PCB.
The main thing to check for is that the tap switcher relay K2 shouldn't click when the PSU is turned on and off at the same output voltage setting.
If it does click when the PSU is set close to the tap switcher's threshold, we should be able to fix it by increasing C1 on the tap switcher or other ways.
