Author Topic: SG marking on PCB component  (Read 3139 times)
Offline made2hackTopic starter
    • Made2Hack
« on: September 30, 2014, 05:13:30 pm »
Hey all,
What does SG mean on a component definition on a PCB?
If R = Resistor, C = Cap, D = Diode, L = Inductor, what is SG?
The component in question is cylindrical / axial about the size of a 0.5 W resistor, no bands, just pink bands over the transparent looking package?
Sorry, I don't have a photo, if need be, will take one.
Offline radioFlash
Re: SG marking on PCB component
« Reply #1 on: September 30, 2014, 05:27:24 pm »
Perhaps spark gap? What kind of device is this component in?
    • Made2Hack
« Reply #2 on: September 30, 2014, 05:36:23 pm »
It is in the beam circuitry from an old CRT Monitor.
« Reply #3 on: September 30, 2014, 06:12:03 pm »
Spark gap for sure then. Used to protect whatever silicon is driving the CRT if the tube flashes over for any reason. In many cases you find a regular neon lamp used in this application if the voltage is under 50V above the cathode voltage. You will often find the CRT base in colour sets also has a built in set of spark gaps on all electrodes, and very high voltage ones on the focus and A1 voltage connections, as they have up to 5kV on them.
