Hello, I made a quick design of a schematic by reading some articles and schematics on the internet. Please find the schematic below.
I decided to use a LM317 power supply for supplying current to the 723 because the voltage from the main winding of the transformer was above 40V dc. Also, I found some time ago that using a regulated supply for 723, make the output voltage more stable (less ripple). So V3 (35V) is a LM317AHVT power supply, which is powered using the same transformer, but using another secondary winding which has 28Vac.
Regarding the value of C7, I established this value by experimenting. Without thic capacitor, there were some oscillations on the R11 (R shunt). Also, I made some quick tests, with the output voltage of the psu at max (30V approx.) and using 1n, 2n2, 4n7 was resulting in oscillations. Also, by connecting the 1n, 2n2 and 4n7 in parallel dampened the oscillation a little. During the tests, the value of C6 was always 100pF.
Screenshots:
1. Oscillations (with the probe of the scope on R11): 31_000, 31_002.
2. With 1n+2n2+4n7 in parallel: 32_000, 32_003.
3. With 10nF: 32_004, 32_006.
4. The simulation file.
Please have a look and tell me what you think.
