Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
LM741 op-amp
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LM741 op-amp (Read 576 times)
selim
Newbie
Country:
LM741 op-amp
on:
December 07, 2022, 05:42:36 pm »
I know that in ideal-opamps the resistor Rs has no effect. But what is the purpose of using the Rs resistor in the circuit for LM741? Will there be any change if we increase or decrease the resistance Rs?
Logged
rstofer
Super Contributor
Country:
Re: LM741 op-amp
Reply #1 on:
December 07, 2022, 06:16:04 pm »
https://electronics.stackexchange.com/questions/570426/why-put-a-resistor-in-series-with-the-positive-terminal-in-a-non-inverting-op-am
Logged
Zero999
Super Contributor
Country:
0999
Re: LM741 op-amp
Reply #2 on:
December 07, 2022, 07:22:36 pm »
R
S
should be 800R, the nearest E24 value is 820R, but 1k is close enough. Actually, with these low values, it doesn't matter, because the bias current is small enough, the additional offset will be way below the 741's offset voltage.
Logged
TimFox
Super Contributor
Country:
Retired, now restoring antique test equipment
Re: LM741 op-amp
Reply #3 on:
December 07, 2022, 10:40:17 pm »
At low resistances, as pointed out above, the bias-current cancellation is rarely important when you do the arithmetic.
However, the 1k resistor on the + input may provide some protection against overvoltage (not much), since it will limit the current into the pin when the input voltage exceeds the common-mode range, or the voltage at the - input when the output reaches maximum.
Logged
Terry Bites
Super Contributor
Country:
Recovering Electrical Engineer
Re: LM741 op-amp
Reply #4 on:
December 09, 2022, 03:09:15 pm »
As noted, it helps reduce the effects of input bais currents.
In many appications this doesnt matter much becasue modern GP opamps tend to have very low bias currents.
Its good idea to add Rs in high gain and temperature sensitive applications.
If your feedback currents are of the same order as Ib, watch out!
RF, Video and Audio opamps designed for low impedance and low noise circuits may have very high bais currents.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
LM741 op-amp
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
