Author Topic: LM78L 05 ACZ  (Read 2045 times)
Offline CramboneTopic starter
LM78L 05 ACZ
« on: June 03, 2023, 12:42:26 am »
Guys how can I test this correctly? I put in a cheap Chinese transistor tester and it shows the following as seen in picture.
Offline Kim Christensen
Re: LM78L 05 ACZ
« Reply #1 on: June 03, 2023, 01:17:06 am »
Those testers can't check a LM78L05... Because it's not a transistor, FET, diode, capacitor, resistor, etc.
They don't check IC voltage regulators, which is what a LM78L05 is.
Re: LM78L 05 ACZ
« Reply #2 on: June 03, 2023, 02:08:36 am »
OK thanks I figured it wasn’t testing it correctly. I tested voltages in circuit and it’s working properly after I found a 100uf cap that tested 17uf.
Offline barshatriplee
  • Country: bd
Re: LM78L 05 ACZ
« Reply #3 on: June 03, 2023, 07:54:37 am »
The easiest way to check these voltage regulator ICs is to use a multimeter and a DC power supply. Give the appropriate input voltage according to the datasheet. And see if you are getting the desired output voltage in the output pin.
Offline Zero999
  • 0999
Re: LM78L 05 ACZ
« Reply #4 on: June 03, 2023, 11:31:30 am »
What made you think the tester wasn't working? It's a transistor tester, yet the L78L05 is a voltage regulator, an integrated circuit, not a transistor. The only way to test it is to build a circuit with it.
Offline Jwillis
Re: LM78L 05 ACZ
« Reply #5 on: June 03, 2023, 05:26:18 pm »
Its an honest mistake to make for beginners. Package design can throw off a novice if they are not familiar with the numbers on the component or with data sheets that may be supplied. even understanding what the data sheet is saying can be a challenge for a beginner.
I did a quick search for the component   LM78L 05 ACZ and found this for you https://www.ti.com/lit/ds/symlink/lm78l.pdf?ts=1685812998671&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FLM78L%252Fpart-details%252FLM78L05ACZ%252FNOPB . The numbers can be slightly different based on the type of package but essentially function the same way. The data sheet will often show you a basic functional circuit.
Good luck and have fun.
Offline donlisms
Re: LM78L 05 ACZ
« Reply #6 on: June 05, 2023, 02:40:44 am »
And... some component testers recognize voltage regulators, though I can't remember which one(s)!  It may have been mentioned in a comparison of the Peak tester and some other.  Sorry.  But I know I didn't imagine it... :-)
Offline Jwillis
Re: LM78L 05 ACZ
« Reply #7 on: June 05, 2023, 04:46:47 am »
I believe the TSH-06F Integrated Circuit IC Tester does. Linear regulators only like the 78XX series.
