Hello everybody,
I have to set up a test bench to test two power supply boards, the first one provides a voltage of 24V (50W) and 48V (200W) and the second one provides a 5V (65W), +12V(7W) and -12V (7W).
I have to measure these voltages with a voltmeter at nominal load.
So, what load can I put on each output ?
Should I use a thermal radiator ? If so, how to choose the type of radiator.
Thank you in advance.
