If there is a break in the insulation, you'll find that there will have been water ingress that will track down the cable by capilliary action.
You might find the break in one location, but the cable will be damaged for meters or more either side, and you'll be digging it up again before long.
In my opinion as an electrician, now is the time to lay a new cable inside a generously sized conduit.
