Poll
Can i directly provide 240Vac to MOC 3023-M?
Yes
0 (0%)
No
2 (100%)
Total Members Voted: 2
Author Topic: MOC 3023M  (Read 2374 times)
Offline ASHUTopic starter
MOC 3023M
« on: July 11, 2015, 04:13:10 pm »
I am new to electronics.
Just wanted to know if I can directly provide 240Vac to the anode of MOC-3023M or should I use a resistor in between?
also will a zero crossing IC like MOC-3042M work on the same voltage?
I have read the datasheets but I don't understand every part of it, still learning.
Thanks in advance
Link to datasheet-
MOC-3023M :  http://www.farnell.com/datasheets/1806097.pdf
MOC-3042M : http://www.farnell.com/datasheets/1639837.pdf
Offline Roeland_R
Re: MOC 3023M
« Reply #1 on: July 11, 2015, 08:26:47 pm »
Max voltage between anode and cathode is 1.5 Volts. Don't use higher voltage. It is an LED on the primary side!
« Last Edit: July 11, 2015, 08:28:23 pm by Roeland_R »
Offline Hideki
  • Country: no
Re: MOC 3023M
« Reply #2 on: July 11, 2015, 09:31:47 pm »
It is meant to be used in "reverse" compared to what you want: To use a microcontroller to control 120/240VAC, and absolutely NOT to use 120/240VAC to control a microcontroller.
Re: MOC 3023M
« Reply #3 on: July 12, 2015, 05:51:08 am »
Ooooo like that
Thanks
Any idea What can i use for my purpose?
Offline Hideki
  • Country: no
Re: MOC 3023M
« Reply #4 on: July 12, 2015, 06:35:12 pm »
Are you not happy with any of the suggestions you already received in your other threads?
Re: MOC 3023M
« Reply #5 on: July 12, 2015, 07:50:36 pm »
No i was
But it's too difficult to find ic like that where I live and online ordering was getting expensive
So I started looking for some cheap alternative
