Author Topic: Logging a voltage and a current in the same time  (Read 2223 times)
Offline AlexReschTopic starter
« on: September 06, 2018, 09:45:36 am »
I would like to log a voltage ( 6.3V ) and a current ( 150mA) in the same time and then use the table to build a graph. Is there a multimeter which can do that at some chosen frequency ( aprox 3-5 times/second ).
Offline KE5FX
    • KE5FX.COM
Re: Logging a voltage and a current in the same time
« Reply #1 on: September 06, 2018, 09:49:51 am »
The Mooshimeter might be a good option for you.  They are quite handy.
The following users thanked this post: AlexResch
Offline RoGeorge
« Reply #2 on: September 06, 2018, 10:04:46 am »
Metrix MTX3283 DMM can log V and I in the same time (3 wires only), fastest sample rate is 1 measurement/second, and the maximum length is about 3000 measurements. The log is kept inside the DMM, so it can log without a PC.
Offline joeqsmith
« Reply #3 on: September 06, 2018, 11:05:24 am »
Five samples/second with V/I may be an expensive meter.   You may be better off with a cheap microcontroller evaluation board with a decent ADC.
There is always the Analog Devices, or in my case I have a Labjack.
Offline JS
  • Country: ar
« Reply #4 on: September 06, 2018, 01:55:37 pm »
121GW?
JS
If I don't know how it works, I prefer not to turn it on.
« Reply #5 on: September 06, 2018, 02:17:51 pm »
I see RS lists it as discontinued. And isn't it French ? Or "frantuzesc" as you people say ?
Offline RoGeorge
« Reply #6 on: September 06, 2018, 03:28:52 pm »
That's what I have, it makes nice charts and could export the logged data. This is an example of logged U and I for a LiIon battery, in order to calculate the battery's capacity.
Yes, it's a French DMM, made by Chauvin Arnoux. "Frantuzesc" is spelled "franțuzesc" in Romanian, with diacritic "ț" instead of "t", but I don't get what's the point about that.
« Reply #7 on: September 06, 2018, 04:30:01 pm »
Well, looks like what I would like - unfortunately it's been discontinued by RS.
No point about "franțuzesc", it just sounds strange. My mother is an ethnic German born in Romania and  I have some passing familiarity with the language.
Online IanB
« Reply #8 on: September 06, 2018, 04:50:27 pm »
My solution to this was to use two or three multimeters, and to create my own logging software that could capture data from several meters simultaneously into one log file.
Offline joeqsmith
« Reply #9 on: September 06, 2018, 05:21:01 pm »
Many of the cheap ones can only sample once per second.  You may need to synchronize and stagger them to get the sample rate up.   Ten UT61Es should do the job.    :-DD
« Reply #10 on: September 06, 2018, 05:31:41 pm »
Found this :
https://www.picotech.com/data-logger/picolog-1000-series/multi-channel-daq
I wonder if it'll do the job. Does anybody have any experience with it ?
Online IanB
« Reply #11 on: September 06, 2018, 06:15:20 pm »
I had good luck with the (now discontinued) Radio Shack model 22-812. When you enable send on the COM port it sends out a continuous stream of data at a rate of 4-5 samples per second. By using USB to COM port adapters I can have as many COM ports on my host machine as I need to plug the meters into.
I have rarely had a need to sample more than about once per second, so I wrote the software to accumulate readings in the background at the maximum sample rate and then log average/max/min for each recording interval. My typical recording intervals have been from 1-10 seconds.
