Hello people, I have a Chinese 8-channel logic analyzer, one of the cheap ones, and I usually use it with the Logic 2 software from Saleae, or sometimes with the pulse view, but due to my ignorance, I never knew which of the software is better and because, since I only use it with small arduino projects and other micros, Spi, I2c, UART etc. I would really appreciate knowing the difference if there is between pulse view and the latest one in Logic 2?
in spanish
hola gente, tengo un analizador ligico chino de 8 canales, de los baratos, y lo suelo usar con el software Logic 2 de saleae, o a veces con el pulse view, pero debido a mi ignorancia, nunca supe cual de los sofware es mejor y porque, ya que solo lo uso con pequeños proyecto de arduino y otros micros, Spi, I2c, UART etc. Agradeceria mucho saber la diferencia si la hay en tre pulse view y la ultima de Logic 2?
