Author Topic: What are the layout foot print dimensions of SLG59M1599V  (Read 238 times)
Offline Sai teja
  • Country: in
« on: January 23, 2019, 11:16:00 am »
Hello ,
I am planning to use SLG59M1599V in an application. But I am unable understand the layout drawing from the datasheet. In layout suggestion, red dotted lines are given around  IC foot print. Someone please explain the significance of dotted lines.
Please refer image for foot print layout.
Datasheet link : https://www.mouser.com/ds/2/665/SLG59M1599r10_12222014-837747.pdf
Please help me in this regard.
Offline Rerouter
Re: What are the layout foot print dimensions of SLG59M1599V
« Reply #1 on: January 23, 2019, 11:19:46 am »
Left is the shape of the pads on the device, Right is recommend pad area, if your PCB pads match the red dotted rectanges., then you have matched the datasheet land pattern
The following users thanked this post: Sai teja
