Author Topic: Anyone have a really old TI databook? TP4306  (Read 2796 times)
Offline timdTopic starter
    • Tim's Random Crap
« on: August 27, 2011, 12:30:20 pm »
G'day All,
I have some old TI 14 pin DIPs here which I can't identify. Does anyone have access to a really old TI databook?
They have the TI logo and are marked:
Line 1:
TP4306AN
Line 2:
M 7519
If the second line means what I think it means it's maybe week 19 in 1975?
There were some other similar TI chips 14 pin DIL marked TP4304AN/7823AET, however I was able to identify those as hex schmitt triggers.
Cheers
Online Psi
Re: Anyone have a really old TI databook? TP4306
« Reply #1 on: August 27, 2011, 01:03:22 pm »
i had a quick look in my old databooks, but the only TP i could find was TP4360 in a cross reference chart.
Offline lowimpedance
  • Watts in an ohm?
« Reply #2 on: August 29, 2011, 04:09:44 am »
Hi
Cheers
HI
 Just a thought, since the TP4304AN was identified as the hex schmitt trigger (same as 7404?) then perhaps the TP4306AN is functionally the same as the 7406. Of course thats just a stab in the dark.
 If you have a number to hand maybe a quick breadboard hookup to test the logic function to see if its the same as the 7406!. Set the 5V PS current limit low just in case (if you can).
    • Tim's Random Crap
« Reply #3 on: August 31, 2011, 12:06:03 pm »
Hi
Cheers
HI
Sounds like a plan. Will report back later.
