Author Topic: Abnormal Waveform of Schottky Diode  (Read 4882 times)
Offline Sainteus
  • Country: my
« on: March 15, 2017, 08:04:39 pm »
We are doing a project on Linear Power Supply and we are trying to choose the diodes with better performance. Thus, we use a gate driver (Power MOSFET) to test the forward characteristic of Schottky Diode (Part Number: SBRT15U50SP5) but we notice that there are these few abnormal symptoms:
  • Abnormal waveform for Schottky Diode.
  • Forward voltage differs significantly compared to the datasheet.
Below is the legend of the graph we get from the circuit.
Vgs which is Yellow colored signal (Channel 1)
Forward Voltage of Schottky Diode which is Blue Colour signal (Channel 2)
Load Resistor (2 Ohm) which is Pink colored signal (Channel 3)
Hoping anyone can clear our doubts. Thanks in advance.
« Last Edit: March 20, 2017, 07:42:23 am by Sainteus »
Online Kleinstein
Re: Long Recovery Time of Schottky Diode
« Reply #1 on: March 15, 2017, 08:41:22 pm »
The current signal still looks good. So I don't see any trouble with the diode. However the horizontal speed is set rather low: even with slow Si diodes the recovery is seldom more than 10-50 µs.
The signal for the diode more looks like a probe problem, or maybe due to AC coupling. How is it measured ?
There is some tolerance in the forward voltage. So a 60 mV difference is not that unusual.
The following users thanked this post: Sainteus
Offline Seekonk
« Reply #2 on: March 15, 2017, 09:01:00 pm »
Why don't you explain what those three signals are and your actual circuit.  I think it is something you are introducing.
Offline Benta
« Reply #3 on: March 15, 2017, 09:07:16 pm »
If your test circuit is just the battery, the resistor and the diode, trying to measure recovery time makes absolutely no sense.
For this, you'll need to go from forward conducting to reverse blocking. Reverse blocking means an actual reverse voltage over the diode. You don't have this.
Perhaps you have a more detailed schematic of your test setup?
Offline Ammar
« Reply #4 on: March 15, 2017, 09:16:52 pm »
Agreed. The diode has a capacitance associated with it turning on and off. If you just open the switch in your schematic, that capacitance will discharge slowly.
Variation in forward voltage is to be expected. However, you may be wondering why it is different from the datasheet, but the same for two diodes. The two diodes will likely have come from the same section of the same silicon wafer and therefore be closely matched. The manufacture of semiconductors uses probabilistic processes and requires lots of testing. Typical yields can be around 30% to 40%.
Offline evb149
« Reply #5 on: March 15, 2017, 10:31:10 pm »
By definition Schottky diodes aren't supposed to have any "recovery time" since there are no minority carriers involved.
https://en.wikipedia.org/wiki/Schottky_diode#Reverse_recovery_time
That said of course there is still a capacitance and stored charge associated with the diode and transit time and inductance so the switching time before the circuit blocks and is not passing current through the "large" power diode will be short but not zero.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: March 15, 2017, 10:40:25 pm »
Your text says "gate driver" but your circuit shows "switch".
The circuit cannot produce the waveforms shown.
Seven Transistor Labs, LLC
Offline Benta
« Reply #7 on: March 15, 2017, 10:52:47 pm »
Which is why I asked for a better schematic. But after one post, OP seems to have lost interest. Let's leave it there and move on.
Offline David Hess
  • DavidH
« Reply #8 on: March 16, 2017, 02:50:05 am »
You could use a fast recovery rectifier for comparison but my guess is that you used a wirewound 2 ohm resistor and are seeing the inductive kickback.
Reverse recovery tests require bipolar drive to reverse the current through the diode and careful high frequency construction including decoupling of the power sources.  The use of a gate driver for the source is a good idea.
Offline Sainteus
  • Country: my
« Reply #9 on: March 16, 2017, 11:11:03 am »
A very sorry for late reply because I am still new in this forum and there are many features that I am not familiar with. We are still doing the experiment and we will keep updating for this subject.
Offline danadak
Offline w2aew
    • My YouTube Channel
« Reply #11 on: March 16, 2017, 02:16:14 pm »
For what it's worth, I did a video on measuring reverse recovery time:
FAE for Tektronix
The following users thanked this post: Bud, orolo, Sainteus
Offline orolo
« Reply #12 on: March 17, 2017, 01:24:10 am »
If you are using a mosfet as the switch, and turn it off letting Vgs fall from 12V to 0V, then the source terminal is pulled to negative -12V by the gate-source capacitance. Since your oscilloscope has a range of 2V in the blue trace, and the capacitance pulls the voltage below that range, it appears flat for so long: in reality, it's below -2V. Then leakage through the mosfet/schottky recharges the source terminal to 0 volts. The diode has nothing to do with the whole proccess, except working as a open switch.
« Last Edit: March 17, 2017, 01:29:09 am by orolo »
Offline Sainteus
  • Country: my
« Reply #13 on: March 20, 2017, 07:16:31 am »
The signal for the diode more looks like a probe problem, or maybe due to AC coupling. How is it measured?
Hi, Kleinstein. Thank you very much for your reply. We also had the same concern as you. The recovery time of diodes surprise us and according to our research, Schottky Diode shouldn't have a recovery period. By the way, we are actually using DC power supply.
Offline blueskull
  • Country: cn
  • Power Electronics Guy
Re: Abnormal Waveform of Schottky Diode
« Reply #14 on: March 20, 2017, 07:20:28 am »
Schematics please.
Offline Sainteus
  • Country: my
« Reply #15 on: March 20, 2017, 07:44:55 am »
Hi, David Hess. Thank you very much for your reply. You are correct I am using a wirewound 2 ohm resistor in the circuit. After considering you advise, I replace it with a film resistor but the waveform I get is still the same.
Offline Sainteus
  • Country: my
« Reply #16 on: March 20, 2017, 07:46:23 am »
Hi, Tim. Thank you very much for your reply. I am very sorry that I had confused you with our schematic diagram. We actually use a Power Mosfet in gate driver to conduct the experiment.
Offline w2aew
« Reply #17 on: March 20, 2017, 12:44:02 pm »
If you're connecting your probe as shown in your schematic, then you're shorting the 2 ohm resistor to ground - unless your scope is floating or you're using a differential probe.
FAE for Tektronix
Offline Sainteus
  • Country: my
« Reply #18 on: March 21, 2017, 02:45:17 pm »
Hi, w2aew. Thank you very much for your reply. I'm not getting what you means actually. But I agreed that it might due to our scope or probe. Hope you can teach me more. I am using Tektronix TPS2014 Digital Oscilloscope, 4 Channels, 100MHz.
http://www2.tek.com/cmswpt/psdetails.lotr?cs=psu&ci=13304&lc=ES-MX
« Last Edit: March 23, 2017, 10:32:02 am by Sainteus »
Offline StillTrying
  • Country: Broken Britain
« Reply #19 on: March 21, 2017, 04:48:41 pm »
If the current then limits at 10A, that'll explain the 360mV Vf across the diode.
CML+  That took much longer than I thought it would.
