Author Topic: Dual OP Amp implementation Doubt  (Read 2772 times)
Offline ramonestTopic starter
« on: July 29, 2017, 07:07:10 pm »
Hello, I was studying some schematics. There was a dual OP amp IC being used. One of the internal amplifiers was being used as (I belive) signal conditioning before doing a measure with an ADC. I think I understand that part.
What I don't understand is that the other OP amp inside the IC was connected: non-inverting to GND, and a 100 kOhm between inverting and output. It isn't connected to anything else, ideally it has no function, but I guess that if they did that it's for a reason. Anyone knows why?
(I probably didn't explain myself too well so I'll add an schematic with the circuit.) Dual OP Amp IC is a TL082 if that's usefull.
Thanks!
Offline Neilm
Re: Dual OP Amp implementation Doubt
« Reply #1 on: July 29, 2017, 07:15:47 pm »
It has been connected like that to stop it floating. You don't want chips to be unconnected as they can end up oscillating and causeing all sorts of problems.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline John B
Offline Lee Leduc
« Reply #3 on: July 29, 2017, 11:16:10 pm »
TI has a good video about this.
The following users thanked this post: Zero999, MK14
« Reply #4 on: July 30, 2017, 12:01:25 pm »
That was helpful thank you all!
Online David Hess
  • DavidH
« Reply #5 on: July 30, 2017, 11:55:15 pm »
There are a couple of other reasons this is important:
1. Terminating the amplifier within its input and output voltage ranges prevents unusual operation and saturation of any stage.
2. Some dual and quad parts share bias stages and operating one beyond its specifications or saturating it will affect the others.
Sometimes you can break the rules and shut an amplifier off by pulling its inputs outside of its input common mode range but this depends on the design.
Offline retrolefty
« Reply #6 on: July 31, 2017, 12:01:10 am »
Of course the same issue applies to CMOS logic chips, unused inputs should be pulled-up/down to prevent problems. Most modern microcontroller chip these days offer programmable pull-up and or down for input pins, making a no cost solution.
Offline electrolust
« Reply #7 on: July 31, 2017, 06:24:17 pm »
https://www.youtube.com/watch?v=gwQiFuckMz0
unfortunate URL encoding on this one
Offline bson
« Reply #8 on: August 01, 2017, 07:10:23 am »
:-DD
