Author Topic: Long Transistor leads  (Read 1620 times)
Offline MapleLeafTopic starter
  • Why don't wands have Si in them? Real Magic!
« on: September 20, 2018, 01:19:51 am »
I have a few old-new stock transistors, JAN2n718a, that have very long leads.
Why the long leads?  For point to point wiring?
And why does it come in a plastic tube? As far as I can tell, these are not special transistors.
These came from a company that does military and commercial air craft.
The picture also shows a plastic pn2222 transistor for comparison.
Offline tkamiya
Re: Long Transistor leads
« Reply #1 on: September 20, 2018, 03:08:02 am »
Maybe that particular transistor had a certain application where that was necessary?  Surely not all transistors came with that long a lead.  Having it come in a tube tells me it was hand-selected as part of the process.
Having said that, I'm from Japan and I recall germanium transistors in 80s that we had, had far longer lead than what we get on 2n2222.  But not THAT long.
Online MK14
« Reply #2 on: September 20, 2018, 04:26:07 am »
With older stuff, PCBs were not always available or used.
E.g. Tag Strip construction.
So, non-PCBs, sometimes needed the very long leads.
Example picture:
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: September 20, 2018, 04:36:40 am »
Mil hardware was often point-to-point or spot welded.  I'm sure there's a spec somewhere for component lead length.
Seven Transistor Labs, LLC
Offline Seekonk
« Reply #4 on: September 20, 2018, 11:40:59 am »
Years ago they also made a big deal out of soldering heat reaching the transistor and damaging it. You were supposed to grab onto the lead with a pliers to stop the heat.  Lead length allowed that to happen.  Probably some truth to that way back when. Now we toast the crap out of them.
Offline schmitt trigger
  • Country: mx
« Reply #5 on: September 20, 2018, 02:07:05 pm »
Exactly!
Germanium transistors were specially vulnerable.
I remember purchasing from Radio Shack a alligator-type heat sink that one would clip to the lead being soldered, to prevent heat from reaching the transistor.
In those days, as we were transitioning from vacuum tubes to transistors, we still used HUGE soldering irons. I had a gun-type iron. Weller. Put out humongous amounts of heat.
Another reason, in the pre-PCB days, the wiring was point to point. The photo posted by MK14 brought out some nostalgia.
