Author Topic: Looking For a Decent Battery Charger For AA/AAA Ni-Cd & Ni-Mh Batteries  (Read 4343 times)
Offline 108CAMTopic starter
  • SkyRC MC3000 Forever!
I'm looking for a decent battery charger that will charge AA & AAA size Ni-Cd & Ni-Mh batteries.
I've tried many over the years and can't find anything decent. I bought a Varta charger like the one that Dave featured in one of his videos and it was good at first but could only charge Ni-Mh batteries. A few years later, all it does is show "Err" for every battery I put in, even the ones that came with it.
I then tried a USB charger that can charge Ni-Mh & Ni-Cd but one of it's slots has stopped working and it often refuses to charge batteries that are good.
Every charger I have tried has had at least one issue and it's left me with a pile of batteries that I don't know the condition of because I can't charge them.
I have checked them with a multimetre but even that can only go so far when it comes to telling me the condition of the battery.
All I want is a decent charger that will charge the good batteries, reject the bad ones and hold more than 4 batteries at once. Any recommendations as to what I should get? I'm sick of wasting my money on junk that never works.
Slowly mastering the art of salvaging 18650's.
Getting better with each pack but still have yet to accomplish my goal of a spark free salvage.
I'll get there someday.
Online beanflying
Re: Looking For a Decent Battery Charger For AA/AAA Ni-Cd & Ni-Mh Batteries
« Reply #1 on: September 07, 2022, 08:26:29 am »
Much as I generally have much more upmarket chargers for my R/C LiPo packs I brought an Imax B6 (or clone  :-// ) just to take a look and have a play. For the $ they are a great option as an all around charger. Add a few 2 or 4 cell holders as needed. The only downside to this sort of charger is that it will to some degree rely on your cells being fairly closely matched if you want to charge multiple cells.
This is an Aussie limited search for them and not much if any gain to be had importing one in this case Evilbay Imax Search
The other 'toy' I picked up some time ago was this USB option USB charger heaps of similar clones and options but it will be more of a hit and miss affair as to what is under the plastic. Mine has 4 independant charge circuits so no need to run a pair of cells. This one sits in the truck and keeps the Scanner and a few other sets of AA's charged.
As to which one - both. The USB option is idiotproof for everyday while the IMax (or similar) is a good way to look at a range of chemistry's under charge if you get one you think is a dud or for just charging at higher currents.
« Last Edit: September 07, 2022, 08:30:58 am by beanflying »
The following users thanked this post: 108CAM
Online wraper
  • Country: lv
« Reply #2 on: September 07, 2022, 08:57:29 am »
It's not the proper kind of charger for these types of batteries. You will be able to charge them but it won't be nearly as straightforward as putting them in. Not to say like 95% of Imax chargers on ebay are counterfeit clones with poor calibration and reliability. For this price you can buy a quite decent universal charger which can charge 4-8 different batteries individually and has similar functionality as IMAX. While IMAX can only do a single battery pack with balancing.
Offline rdl
« Reply #3 on: September 07, 2022, 09:11:29 am »
NiCd is mostly dead and buried. I've bought several NiMH AA/AAA chargers in recent years that work fine, Nitecore D4 is one. I also have a couple from EBL that do 9 volt, both NiMH and Li-Ion, which I have been very happy with. The Fujitsu has been in use for years now with no problems. I also have a Panasonic version (BQ-CC17) that works just as well.
Online beanflying
« Reply #4 on: September 07, 2022, 09:18:06 am »
For 30+ years I have been charging 4 and 8 cell pack in both NiCads and Nimh for Tx and Rx use with peak detection chargers. You are WRONG these chargers are a very 'proper' option for this but as I clearly stated that does rely on the packs being somewhere near matched. Not all of the world or equipment works on single discrete cells.
'balancing' (completely the wrong term) of single cell NiMh or Nicads in no way guarantees that those individual cells have capacity X or can deliver Current Y. 'Universal chargers' are largely full of marketing spin and glorified  :bullshit:
Further dumping on Imax/clones for 'poor calibration' in your opinion while praising random non specified 'Universal Chargers' as a superior option is complete :bullshit:
Offline MrAl
« Reply #5 on: September 07, 2022, 09:31:47 am »
Look for a charger on a site like Amazon.  They have a lot of different ones at different prices.
Look for one that also TESTs cells not just charge them.  That way you can test a cell after it has been charged to get an idea how well it works as it gets older.  These are typically 4 bay chargers that have an LCD display.
They also have different current settings for NiMH cells such as 500ma, 1000ma, 1500ma, 2000ma, etc.
They also sense the condition of the cell and if the resistance is too high they automatically cut back on the current so the cell does not get too hot.
They also show the terminal voltage while charging, the ampere hours, the time, and of course the actual charge current which may vary for each cell.
The discharge test tells you if the cell is getting too old.  For example if the cell can hold 2000mAh when new and it is tests as low as 1000mAh then it must be getting old and so wont run a device as long as when new.
A typical charger that does all that is the OPUS BT-C3400 but i am sure there are others in that price category which is probably around $40 USD.
Online wraper
  • Country: lv
« Reply #6 on: September 07, 2022, 09:35:06 am »
Op asked for charging individual cells  :palm:. I own genuine B6AC btw and barely use it. Because it's mainly meant for RC LiPo battery packs.
I was talking about IMAX B6. That it has only one output and all it can do is balance a battery pack if there are taps between the cells.
Yeah sure, mentioning that ~95% of chargers over that link are counterfeit is a blasphemy. OP certainly should not know about that. And do not put words in my mouth, I was talking about counterfeits being poor, not genuine item. But suggesting a charger meant for battery packs for use with individual cells is certainly the smartest thing ever.
Online beanflying
« Reply #7 on: September 07, 2022, 09:44:40 am »
And as per USUAL only the word of Wraper can be right.  :palm: when in fact  :bullshit: rules because you are an all knowing  god and only brand X approved by you is the best so all other opinions are wrong :-DD
No One I can think of 'balances' packs of NiMh or NiCads and in 30 + years of punishing the hell out of NiCads and NiMh we have never done it. Your use of the term was WRONG deal with it!
You made a 'rash generalization' to dismiss the Imax/clones without supporting evidence and further claimed 'universal chargers' also likely clones of dubious quality being superior. Ambit claims are not factual so therefore  :bullshit:
« Last Edit: September 07, 2022, 09:46:20 am by beanflying »
Online tszaboo
« Reply #8 on: September 07, 2022, 09:45:59 am »
I'm using the "Liitokala 500" for all my charge/discharge tests for all AA/AAA or 18650 and other lithium batteries.
You can set the charging current, and do discharge tests or refresh the battery.
https://lygte-info.dk/review/Review%20Charger%20LiitoKala%20Lii-500%20UK.html
For AAs and AAAs I switched to LSD batteries like Eneloops a while ago.
Online wraper
  • Country: lv
« Reply #9 on: September 07, 2022, 09:54:35 am »
No One I can think of 'balances' NiMh or NiCads and in 30 + years of punishing the hell out of NiCads and NiMh we have never done it. Your use of the term was WRONG deal with it!
Can you actually read what was written or what? And not put words in my mouth? IMAX cannot charge multiple cells individually is what I said. IMAX B6 can balance lithium cells for sure. I don't care if balancing feature in B6 actually works or does not work for NiMh, I did not make any claims about that. Such battery packs normally do not have taps anyway. Half decent chargers for multiple single cells just charge them individually.
« Last Edit: September 07, 2022, 09:59:09 am by wraper »
Online beanflying
« Reply #11 on: September 07, 2022, 10:29:38 am »
Speaking of YOU NOT READING what I wrote including a discussion on well matched cells by me. You got on the pulpit and made unfounded and ambit claims as to suitability which are WRONG technically, practically and with several decades of my experience WITHOUT MERIT. So yep I call :bullshit:
Again you mention '1/2 decent' Universal Chargers and again with more than a few I have looked at and used over the decades most are of dubious quality and functionality including several that have failed. They are full of marketing BS and fail all to frequently to even charge what turns out to be an ok cell(s). You have given the OP you now seem concerned about ZERO help as to one other than preaching they are the 'best' option.
Unlike even charging several separate cells in a holder and putting on them an IMax/clone will not give anything more than a guess as to capacity added during the charge or their ability to deliver it back out. The charger the Imax was cloned from originally was the Hyperion EOS5i which is and will always be a better option and mine and the IMax (they are ALL Clones) I got actually stack up fairly well in performance and function.
They 'Universal Chargers' are 'an option' but frankly often a flawed one and come with limited options and functionality but if you get a working one for an idiotproof solution they have a place.
As to 'balancing' how on this planet do you 'balance' a single NiMh/NiCad pack or cell as some sort of charge state? It was and remains a wrong term and YOU TYPED IT!
« Last Edit: September 07, 2022, 10:33:15 am by beanflying »
Online wraper
  • Country: lv
« Reply #12 on: September 07, 2022, 10:36:06 am »
As to 'balancing' how on this planet do you 'balance' a single pack NiMh/NiCad pack or cell as some sort of charge state? It was and remains a wrong term and YOU TYPED IT!
Again point to a single place where I said it can balance NiMH/NiCd  :palm:.
Offline Black Phoenix
  • Country: hk
« Reply #13 on: September 07, 2022, 11:25:53 am »
You know just because it says Balanced that doesn't mean it does to ALL the battery types it supports.
Same way as an USB 3.0 norm port does support the max speed if the device is an USB 3.0 compliant, being slower speeds for other norms (sorry for the analogy but it is the best one I came).
Offline Circlotron
« Reply #14 on: September 07, 2022, 12:38:14 pm »
I got one of these about a year ago and I'm quite happy with it. AUD$100
https://www.protog.com.au/maha-powerex-mh-c9000pro-aa-aaa-nimh-battery-charg/MHC9000PRO
Offline BILLPOD
« Reply #15 on: September 07, 2022, 01:04:42 pm »
https://www.skyrc.com/MC3000_Charger
This is not cheap, but it does it ALL.
I have had mine for about 2 years and I love it :popcorn:
Online magic
« Reply #16 on: September 07, 2022, 01:40:11 pm »
A few years ago I scored a used Opus BT-C700 on an auction site, very cheaply because it looks like everybody wants Li-Ion support nowadays. Nice little charger (and discharger), my only complaint is that there is no way to force it to start charging a cell depleted down to zero, it just thinks the slot is empty.
More than you ever wanted to know about battery chargers:
https://lygte-info.dk/info/indexBatteriesAndChargers%20UK.html
Offline bdunham7
« Reply #17 on: September 07, 2022, 02:07:48 pm »
I'm using the IQ338XL which seems to be excellent, but it is both more and less than you are asking for as it does AAA/AA/C/D NiMH and 18650 Li-Ion as well, but has a 4-cell maximum.  I suppose you'd need two of them to meet your needs.  Strictly for AAA/AA NiMH, the Panasonic BQ-CC17 is also good, but slower and only 4 cells.  Other Eneloop-associated chargers may or may not be good as well.
I have a good half-dozen other no-name and EBL-branded chargers that are crap.  So shop carefully and read reviews.
Offline nightfire
« Reply #18 on: September 07, 2022, 02:19:30 pm »
Some hints may be gotten here: https://lygte-info.dk/info/indexBatteriesAndChargers%20UK.html from the page of one of our forum members.
I have had the AV4m (from MEC or IVT) charger for some time, where I was very happy with, and after the power supply died, I helped myself to a Xtar VC4L (which is ok and affordable) to also be able to charge some Lithium cells.
Especially with Eneloops, I really loved the AV4m, the discharge function was able to get some strange cells on track again.
Offline james_s
« Reply #19 on: September 07, 2022, 05:06:41 pm »
I've been using a Lacrosse BC-900 for years and it works really well. Forget about RC chargers like the Imax, you want something that can charge multiple cells of different types individually. For years I got by with basic chargers that charged in series before I got one with individual channels and that is a huge step up in convenience.
Offline GLouie
« Reply #20 on: September 07, 2022, 07:58:04 pm »
OP's requirement for more than 4 cells and NiMH+NiCd leaves little choice. IIRC, a NiMH charging algorithm is not exactly best for NiCd and it is never clear if a unit is optimized for one or the other. I do have a Powerex-Maha C801D that fits that spec (8-cell, NiMH and NiCd, AA or AAA) and it has worked fine but I only use it for AA Eneloops in "slow" mode (1k mA) and could not say if it will work on marginal cells with low voltage or high internal resistance. Some chargers certainly balk at marginal cells and some have no problem.
Offline james_s
« Reply #21 on: September 07, 2022, 08:24:24 pm »
Requirement of more than 4 cells does limit things, although most of the 4 cell chargers are compact so it wouldn't be a big issue to set two or more of them side by side to charge the number of cells needed.
« Reply #22 on: September 08, 2022, 12:34:59 am »
Thanks for all the replies. Seeing that I'm quite limited when it comes to chargers with more than 4 slots, I may settle on something with 4 slots.
My USB charger still works fine with the only issue being that only 3 of the 4 slots work. I'll still keep my other chargers but will still definitely consider buying a new charger that will give me a more accurate indication on what batteries are good and which ones are bad.
Do chargers with a "Refresh" function actually extend the life of batteries? I tried using the Refresh function on my Varta charger and it appeared to work but then the batteries I tried to refresh lost their ability to hold a charge and begun to leak shortly after.
https://outdoorcameras.com.au/shop/16-cell-battery-charger/?gclid=Cj0KCQjwguGYBhDRARIsAHgRm49GThiQbaLSKPnrgtsTM85tmpbUxA353ki6knkCs1-SAK5BrB1EwPQaAmTkEALw_wcB
This is what I was thinking of. Does anyone have experience with this charger? It will be perfect for all my Ni-Mh batteries and my USB charger can take the Ni-Cd's as it's very good at charging the good ones and rejecting the bad ones.
Offline james_s
« Reply #23 on: September 08, 2022, 01:23:28 am »
The Refresh feature works with certain batteries, I have had it restore capacity of cells that got deeply discharged to the point of being slightly reversed. Many nickel based cells take a few cycles to reach full capacity and Refresh will do that. If a cell is truly worn out though there's nothing a charger can do to fix it.
Offline todorp
« Reply #24 on: September 08, 2022, 08:10:22 am »
Please look here:
Lots of info, very useful. The guy is very active in this forum too, so you might ask him...
Oh, sorry, I see @tszaboo has already posted this link...
