Author Topic: Where do you guys get inductors?  (Read 3013 times)
Offline Dylon124Topic starter
« on: October 07, 2013, 01:09:21 am »
I need a 33uH inductor for cheap fast for an smps I designing!
Offline Toble_Miner
  • Into electronics, C, C#, Java, AVR, Linux, Brony
Re: Where do you guys get inductors?
« Reply #1 on: October 07, 2013, 01:17:34 am »
maybe Digikey has what you're looking for.
Tobias
Offline walshms
« Reply #2 on: October 07, 2013, 01:18:08 am »
www.mouser.com is another good resource.
Offline Kryoclasm
  • KL3DL
« Reply #3 on: October 07, 2013, 02:00:43 am »
Roll your own!
Air core inductor:
33.035 µH
Coil diameter  15mm
Coil length   10mm
Number of turns 50 t
Wire length 235.62 cm
If you want to use a soda bottle cap as a form, then try this...
Coil diameter  30mm
Coil length   14mm
Number of turns 32 t
Wire length 301.59 cm
http://www.m0ukd.com/Calculators/air_core_inductor_calculator/
« Last Edit: October 07, 2013, 02:05:33 am by Kryoclasm »
“I predict that very shortly the old-fashioned incandescent lamp, having a filament heated to brightness by the passage of electric current through it, will entirely disappear.” -Nikola Tesla
Offline hechen
« Reply #4 on: October 07, 2013, 02:02:43 am »
Where are you located?
If in the US http://www.newark.com/ is a good source as well.
Offline Toble_Miner
« Reply #5 on: October 07, 2013, 02:05:13 am »
@Kryoclasm:
This guy is actually designing a SMPS. I don't think an air core inductor will work too well for him. I suspect he targets a efficiency > 1%.
EDIT
Also for filtering purpose an air core inductor would not be suitable. An iron-powder core inductor would be much better.
« Last Edit: October 07, 2013, 02:08:23 am by Toble_Miner »
Offline Kryoclasm
  • KL3DL
« Reply #6 on: October 07, 2013, 02:06:04 am »
i see.
Offline simpson
« Reply #7 on: October 07, 2013, 02:47:18 am »
Mouser, Digikey or eBay.
Offline vk3yedotcom
    • vk3ye dot com (radio articles and projects)
« Reply #8 on: October 07, 2013, 08:34:36 am »
jaycar.com.au
NEW! Ham Radio Get Started: Your success in amateur radio. One of 8 ebooks available on amateur radio topics. Details at  https://books.vk3ye.com
Offline TNb
« Reply #9 on: October 07, 2013, 08:58:26 am »
Sometimes it is really faster to make your own, than wait for it week or two to be delivered. It is not so hard, google it, a lot of instructions out there.
