5V for the power isn't a bad assumption, but it's hard to be sure without knowing more about the specific camera. Basically what you want to do is this:
Get a male Phono/RCA connector
Connect the "pin" of the connector to the yellow wire
Connect the shield/ring of the connector to the black wire and to the ground of your power supply
Connect the red wire to the V+ of your power supply
