I am working on a simple project that requires some high-current signals to be passed between 2 PCB's in a 1-meter distance. There are in total 50 signal wires in 2 channels (channel A is 26 wire, channel B is 24 wires). There are about 50 signal wires to be connected between these boards. I have already purchased the wires, and they are AWG18 or 16...or should I say a tad bit thicker than your normal jumper wire, to make sure the 1A current would not be a problem in long run.
THE PROBLEMI can not figure out what would be the best through-hole socket and its matching connector for this job. It should have the following properties:
- Minimum 1A rated
- It should have locking mechanism
- The matching connector should allow easy installation of AWG18 wires
WHAT SO FAR?I am thinking about 3x20 pin ATX power supply connector and socket, just like what you find on a PC motherboard:
Unfortunately, I could not find this item on digi-key or Farnell
maybe you can helo me to find it on those websites?
Furthermore, I really would like to know if you might have a better idea, please let me know the name/picture or item id of the socket and matching connector that you think would do better than that ATX PSU connector!
Thanks!
