The second schematic shows a another super-regenerative receiver, but I would judge that this circuit is poorly designed and although it probably does work, it probably doesn't work as well as the first circuit despite having many more components.
However, the reason this circuit works at all is probably due to the large amount of components clumsily hooked together and fiddled with to achieve some low level of performance, and this circuit probably only works at all within a narrow range of signal conditions.
Looking at the design of Q1 working as a common-emitter RF pre-amp and also the overal circuit, I would wager this entire circuit would show very noticeable varying performance if you had a chance to compare several identical units.
This circuit seems to be poorly designed, a result of trail and error design, doesn't look like the work of an experienced RF design engineer. It is a kludge.
If you choose to study super-regen circuits, I would suggest you find a better circuit to study.
