Google has failed me on this, nothing but residential lighting and wide screen TVs. I'm after an LED light source which will remain relatively bright when viewed from a wide range of angles, say about 60 degrees from frontal in all directions. Like a small incandescent bulb, which wouldn't work btw because short (15mS) flashes are involved. Supply can be up to 9 volts, with suitable current limiting if needed.
I could rig up multiple LEDs in series, but would like a single device for aesthetic reasons.
Is anyone aware of a type or source, only a very small number needed.
