Author Topic: PC1602-h i chowdered the ground pin.  (Read 1039 times)
Offline ionicwakeTopic starter
« on: March 31, 2017, 07:05:45 am »
so, as you can see by the pictures, i chowdered this thing but good while trying to solder a wire to the ground pin. now i have looked up the pinout and i have tried to solder to the ground plane in hopes of resurrecting this poor thing to no avail. is there anywhere else i could attempt feeding power through? I would rather use this thing then having it hit a landfill.
http://i653.photobucket.com/albums/uu252/ionicwake/20170331_001803.jpg
thanks!
Ion
« Last Edit: March 31, 2017, 07:13:09 am by ionicwake »
Offline bktemp
Re: PC1602-h i chowdered the ground pin.
« Reply #1 on: March 31, 2017, 09:15:32 am »
You could try the golden pads the metal frame is connected to. Since they are connected to traces there is probably a solerable jumper somewhere for shorting them to GND.
Maybe R8 or R9 or J5.
