Hello, I have a Weller soldering iron. Can't find the specs but it has a red triangular shape at the front like the SP40NKUS 40. The problem with it is that when I used it with a heat-set insert tip, sometimes the short insert tip and thick shaft (about 10mm in diameter) of the soldering iron caused the iron's shaft to touch or almost-touch the nearby plastic and melt the plastic by accident. Any other good product recommendations? I guess I need a soldering iron with shaft about 5mm in diameter or heat-set insert tip with longer tip.
