Author Topic: LoRA range question  (Read 893 times)
Offline AndrewMTopic starter
LoRA range question
« on: October 10, 2019, 05:54:34 pm »
So, supposedely LoRA has 10km line of sight range?
In theory, (ignoring airspace and radio regulations for now), if I had a LoRA device on a weather balloon, it would be able to talk to the ground until it hit ~10km altitude?
I'm not actually planning to do anything of the sort, I was thinking more along the lines of a LoRA relay stuck on an RC plane that could circle over an area and get line of sight to a bunch of LoRA devices on the ground that otherwise wouldn't have LoS due to hills, mountains, trees, etc...
Offline sokoloff
Re: LoRA range question
« Reply #1 on: October 10, 2019, 06:11:48 pm »
Each doubling of distance in free air costs you -6dB in link budget. The distances possible in free air are wildly longer than 10km.
https://www.thethingsnetwork.org/article/ground-breaking-world-record-lorawan-packet-received-at-702-km-436-miles-distance
Offline Adrian_Arg.
  • Country: ar
« Reply #2 on: October 10, 2019, 06:23:25 pm »
I have tested this Reyax rylr 896 Lora module SX1276 up to 8.80 km
Offline floobydust
« Reply #3 on: October 10, 2019, 08:23:06 pm »
I can't find what antenna the air balloon used. Antenna gain and directivity are important.
Offline Whales
    • Halestrom
« Reply #4 on: October 10, 2019, 11:35:24 pm »
Also: if you are using only a single balloon then it may be possible for your ground station to have a directional antenna.  That's assuming you are running your own station and not using a public network one.
