Author Topic: Help Identifying Components Please  (Read 607 times)
Offline Robbie010Topic starter
« on: February 03, 2019, 04:16:00 pm »
Hello all,
I have a few components in my project amplifier that I can't seem to identify the values for, any help much appreciated!
Small clear Capacitor? Only markings are 39F and a feignt red band
All gray capacitors / resistors? marked EFM3 033Ohm 2%
Unmarked Output Transistors, tested with Multimeter Continuity setting and only get reading on the case / collector
Orange capacitor? marked 1K 100-130?
Thanks in advance.
« Last Edit: February 03, 2019, 04:29:08 pm by Robbie010 »
Offline Benta
Re: Help Identifying Components Please
« Reply #1 on: February 03, 2019, 05:55:29 pm »
Hello all,
Small clear Capacitor? Only markings are 39F and a feignt red band - 39 pF polystyrene
All gray capacitors / resistors? marked EFM3 033Ohm 2% - 0.33 ohm, 2 W resistors
Unmarked Output Transistors, tested with Multimeter Continuity setting and only get reading on the case / collector - no idea
Orange capacitor? marked 1K 100-130? - 1 nF polyester
Thanks in advance.
Offline PA0PBZ
« Reply #2 on: February 03, 2019, 07:24:44 pm »
Hello all,
39pF
Either 33 or 0.33 Ohm, trust your multimeter.
I have no idea.
1nF
