I'm just checking a 750W PSU that might or might not have problems. It powers up fine, and starts a little dual core PC. Looking at the outputs tho IDK if it's normal or not.
It's switching at ~140kHz
So the 12V rail, I get the inductive ringing of 2.0Vpp max on the 1st ring, 1.25Vpp by the 2nd ring, and by the 6/7 ring it's decayed to next to nothing. Those rings in total span ~600ns, the period of the switching is 7us.
The 5V rail looks the same shape/time wise, with the 1st ring max of 1.84Vpp, 1.33Vpp on the 2nd, and drops off by 6-7 rings.
The ripple looks fine. I'm just wondering if those inductive spikes sound about normal at 2Vpp ?
I could pull the output caps and check ESR. I don't have any proper way to load test these PSUs, this test rig is under well under 300W.
