Hi!
It's my first time posting here and I'm still relatively new ( finished learning electronics in trade school, about to start in college )
I'm not really sure if this topic should go here or in the 'Projects, Designs, and Technical Stuff' section so feel free to let me know if I should take it somewhere else.
I've been thinking about rolling my own differential probe for troubleshooting switch mode power supplies. Currently I only have schematic and I'm planning to build it on a proto - board. I'm not going to bother to design a full PCB for it.
My main requirements are:
- Minimal cost ( re-using components from scrapped projects )
- DC coupled
- At least 400V input common mode range
- 500kHz bandwidth or more
- Multiple attenuation ranges
- Ability to drive 50 Ohm Coax at full swing
- Powered by single external power supply or lab power supply
- At least 1M input impedance
DC accuracy is not a big concern here, but still I won't use 5% carbon resistors in a voltage divider
I decided to use as many parts as possible from my own stock.
Long story short it's using 2 voltage dividers with instrumentation amplifier driving the output.
Dividers consist of five 220k resistors in series, with 10k and an array of nine 10k resistors in parallel (equivalent resistance of exactly 1111,(1) Ohms. Input signal is tapped off at both sides of the 10k resistor. All resistors are 1% 50ppm/K rated, 220k are also rated for higher voltage (350V). Overall Input impedance is 1,1111... MegOhm minus capacitor leakage.
Capacitors C1 - C10 are 8,2pF 500V NP0 dielectric, then a combination of caps to form 180,4pF parallel to 10k and another combination equivalent to 1,623nF. Trimmer caps are used to precisely set the capacitances to improve frequency response.
Diodes D1-D4 serve as a crude input protection. 1N4148 have relatively stable junction capacitances when biased with a reverse voltage higher than 2V ( In this case they will be biased with at least 10V at all times ). Ferrite beads FB1 and FB2 take the edge off a high frequency pulses that would couple through divider capacitors (don't have any data on them ).
Range switch is used to change the input divider ratio and INA gain to get 4 different ranges:
X1, X10, X100, X1000
All of the ranges will survive high voltage on the input ( up to 1750V - 5 resistors with 350V withstanding voltage ) but high common mode or differential voltages might saturate the INA - more info on the attached shcematic.
Instrumentation Amplifier uses classic 3 Op-Amp configuration with IC2 gain set permamently to 2 ( to compensate for output termination ) IC1 is a jellybean TL082 because of it's FET inputs and okay bandwidth. I haven't really settled on the choices for IC2 ( I have a LT1028 - kind of overkill except high bias currents or CA3140 - CMOS input with external offset trimming )
Gain of IC1 is set by the range switch selecting the coupling resistor ( at X1000 there's no coupling, at X100 theres an array of resistors equivalent to 2222,(2), at X10 and X1 it's 201,5). IC2 drives the output buffer consisting of Q1-Q2 and Q3-Q4 transistor pairs. Both pairs are paralleled to be able to withstand shorts at the output at full drive. D6 and D7 provide bias voltage and R38 is the 'current source'
. Ferrite beads at the bases prevent the output stage from oscillating ( I accounted for lead inductances from my sloppy wiring ) whole buffer stage is under IC2's feedback loop to further improve accuracy and linearity.
Output of the INA is terminated with two 100 Ohm resistors connected in parallel to make 50 Ohm.
Supply rails are provided by a single floating power supply through C24-L1-C25 common mode filter. R61 and R62 force the supply to be symmetrical in reference to oscilloscope ground. C26-C29 filter the rails. Value of 330 Ohm is arbitrary, lowering the resistance decreases the loss of symmetry when output has a DC component, but higher resistance decreases the power dissipation. I'm not sure if I can get away with that, but the design needs to fit in a small case. Let me know if I should add some active components in there.
D5 is crude overvoltage/ESD/reverse polarity protection.
Soon I should get to actually building the circuit to see how it works.
One more thing:
What if I could use Thevenin resistance of input dividers as a gain resistor in a single op-amp difference amplifier?
This would greatly simplify the design and make it easier to fit in a case that I want to use.
Feel free to share your suggestions and ideas
I'll keep you posted on the progress
