Author Topic: Low Impedance Amplifier Suggestions  (Read 917 times)
Offline darthhideousTopic starter
« on: January 09, 2019, 12:47:26 am »
Hi all,
I'm looking for an amplifier capable of driving a 2 \$\Omega\$ (preferable) or 4 \$\Omega\$ (predominantly resistive with small XL) load with a minimum output power of ~100W. The required bandwidth is 50Hz - 200kHz. I'm not after a perfectly flat response across the band however at least 50W output is required at 200kHz. Operation would not be continuous with an estimated min duty cycle of 1 min on, 3 min off. Does anyone have suggestions for an off the shelf solution or alternatively power op-amps that could do this? I've had a look at the OPA549/OPA541 but they look dicey around 200kHz. I tried two LM3886s in parallel and they worked okay but hit their limit at around 200kHz.
Thanks!
Offline David Hess
  • DavidH
Re: Low Impedance Amplifier Suggestions
« Reply #1 on: January 09, 2019, 01:37:05 am »
What kind of distortion levels are acceptable?
Let's see; 100 watts into 2 ohms is 3.5 amps 7 volts so 7 amps 14 volts peak for sine waves.  What you are describing is essentially a super class-AB audio amplifier.  If you do not want to go the discrete route, then a part like the Apex MP111 is more than suitable if driven by a high level signal.  Another alternative would be something like several 7-lead TO-220 LT1210s in parallel.
I would probably try a variation of the first circuit included below using fast D44/D45 output transistors but that is just me.  My own old but similar discrete audio amplifier design had a bandwidth above 500kHz using much slower output transistors.
