Author Topic: Connector pins  (Read 1584 times)
Offline tony3dTopic starter
Connector pins
« on: November 03, 2014, 02:18:18 pm »
HI Everyone, any idea where I can get large enough pins to use on these type of connectors, so the tiny screws don't bend them out of shape? couldn't really find anything on ebay.
Offline janoc
Re: Connector pins
« Reply #1 on: November 03, 2014, 04:42:42 pm »
Aren't those standard wire connectors? I.e. you take a piece of solid core or stranded wire and tighten it inside the tube with the screw. There aren't any "pins" to go in there.
And the other "end" of the connector is normal DC barrel jack.
« Last Edit: November 03, 2014, 04:46:40 pm by janoc »
