Newbie here... I am working on a thermostat pcb; the board receives 24V AC from the furnace, and uses LM2596 to convert it to 3.3V DC. Logic runs on ESP32 which switches three through hole relays (fan, power, heat/cool). The board has a ground plane and a 3.3V plane covering the whole board. I have a (hopefully) very simple question: is it ok to run 24V AC traces inside these planes, or would I be better off not doing that? I didn't give it a second thought at the beginning, but recently discovered a bridge of solder between one of relay contacts that switches 24VAC, and a 3.3V plane. I would lean towards routing AC traces away from the planes if I were doing the board from scratch, but unfortunately it is almost complete.
Thanks.
