The single bridge + series pair of secondaries with center tap is only an option if the secondaries are well matched both in voltage and DC resistance. If not, its best to connect each secondary direct to the AC terminals of its own bridge rectifier and *ABSOLUTELY* *NOWHERE* *ELSE*, then 'stack' the outputs of the bridge rectifiers.
For the single bridge circuit, the usual configuration is to ground the center tap for equal + and - rails out of the bridge, but if you ground the - side of its output, the center tap of the secondary will supply half the DC voltage of its + terminal.
