Author Topic: N-Channel MOSFET for switching 400mA @ 3.3V  (Read 1313 times)
Offline TantalTopic starter
« on: June 11, 2015, 07:22:17 am »
I am looking for a logic level N-Channel MOSFET for switching 400mA @ 3.3V (I'd like to turn on/off LEDs with a 3.3V Arduino).
RDS,on and VGS(th) seem to be the key parameters here, no?
Which one would you recommend?
Offline con-f-use
  • Country: at
Re: N-Channel MOSFET for switching 400mA @ 3.3V
« Reply #1 on: June 11, 2015, 08:02:15 am »
1. Go to mouser or the distributor of your choice
2. Look for N-MOS, filter for >500 mA, a threshold voltage <2V and maybe the package (smd, through-hole)
3. Order 100 of the cheapest
The majority of N-MOS on the planet should suit your needs. A typical jelly-bean is the NTR4170.
(Bonus Points: Calculate on-state power and compare it to the datasheet's thermal characterisitcs, most should take your 400mA without hesitation, unless you plan to switch really rapidly)
« Last Edit: June 11, 2015, 08:12:36 am by con-f-use »
