Author Topic: distortion at low volume stereo amp  (Read 4438 times)
Offline kasumykuTopic starter
« on: January 30, 2014, 03:57:25 am »
hello everyone!
found a pair of pc speakers in recycling room( wrong place to discard electronics...) and hoped that wont work so I can learn more about electronics and my wish came true:))) but now I cant figure out what the problem is...
-symptoms:
sounds OK up to about 10% of the volume, anything after that sounds distorted.
-what I have checked so far:
1)looked for shorted wires, but doesn't sound like shorted wires because it sounds clear up to 10% of its volume
2) found a leaky capacitor, checked it with ESR meter, much higher resistance than what it should be... replaced bad capacitor and same symptoms...
Brain of this little amp is a TEA2025B chip... everything else on the board is only caps, 1 pot for the volume(also is for on or of )and 1 transistor which i pulled it out of the board and it checked good.
Any guidance would be much appreciated and thanks in advance!!!
« Last Edit: January 30, 2014, 04:01:10 am by kasumyku »
Offline Greg Robinson
Re: distortion at low volume stereo amp
« Reply #1 on: January 30, 2014, 04:02:34 am »
1st rule of electronics repair: measure voltages!
« Reply #2 on: January 30, 2014, 04:06:02 am »
Any wake up call its more than welcome, but guidance would more appreciated...
« Reply #3 on: January 30, 2014, 07:49:48 am »
Well, have you actually measured voltages? If you did you didn't mention it, just testing caps and a transistor, something beginners will often do while forgetting about voltages.
Tac Eht Xilef
  • Guest
« Reply #4 on: January 30, 2014, 02:49:29 pm »
a) As everyone's mentioned, measure voltages. Without that basic level of troubleshooting you're not fault-finding, your guessing.
b) Dunno about that chip particularly but most similar ones of that time & ilk are notorious for either being really prone to supersonic oscillation unless the layout and surrounding circuitry is spot-on, or half-dying and distorting at higher volumes.
Voltages. Datasheet. Compare...
« Reply #5 on: January 30, 2014, 08:31:14 pm »
Distorted sound means change the 100uF capacitors attached to pins 3 and 14. Use ones rated for 25V or more. That should improve things a lot, but it is still a pretty low fi unit.
Datasheet here.
http://www.futurlec.com/Datasheet/Linear/TEA2025.pdf
