Hi all,
I have an older Tektronix 2445A 'scope that needs a new pair of probes. The only work I do is in the audio realm. Highest frequency I would test would be the bias frequency of an analog tape recorder (432 kHz).
My friend has a set of Pomona 6493 probes he would consider selling me. I did some research and found that these are 60MHz. The Tek 2445A is a 150MHz scope.
I've researched online, seems everyone suggests going with probes that are higher bandwidth.
What's issues would I encounter (for audio work, if it matters) with using 60MHz probes with a 150MHz scope?
Thanks!
