Hi guys,
I'm trying to simulate a circuit I have to build. I have a pulsing current source of amplitude 1mA and duty cycle 50%. The frequency of this source will vary from DC to 1Mhz.
Just to test I put together this circuit in LTSpice to check the behavior.
I set a low pass filter to around 33Hz, the rest of the filtering can be done digitally.
I simulated the frequency at 1Khz and 1Mhz and I found that the output voltage of the opamp is the same (500mV).
1Khz:
1Mhz:
Why is that? I thought the output at 1Mhz would be way lower due to the LPF.
That is actually the behavior that I want for my circuit, but I just can't understand why isn't being attenuated at higher frequencies
Thanks!
