Author Topic: LPF question  (Read 1490 times)
Offline stoica adrianTopic starter
LPF question
« on: July 13, 2018, 03:00:38 am »
Hello,
I have two qestions, if you can help me.
What happens after you pass the 3db point of a LPF, and witch is the maximum ° that you can obtain with a LPF?
Offline Bassman59
  • Yes, I do this for a living
Re: LPF question
« Reply #1 on: July 13, 2018, 03:49:04 am »
Hello,
Pass it from which side? To the right (increasing frequency) of the 3 dB point, the response increases towards unity, at which point it flattens out. To the left of the 3 dB point, the response decreases with a slope given by the number of poles in (the order of) the filter. One pole, your attenuation goes as 6 dB/octave. Two poles give an attenuation of 12 dB/octave, and so forth.
That too depends on the order of the filter.
Offline Circlotron
Re: LPF question
« Reply #2 on: July 13, 2018, 04:09:56 am »
RC low pass filter output would approach 90 deg phase lag, I expect.
Probably never quite get there.
Online David Hess
  • DavidH
Re: LPF question
« Reply #3 on: July 13, 2018, 11:45:07 am »
90 degrees maximum per pole or order.
Offline Audioguru
Re: LPF question
« Reply #4 on: July 15, 2018, 03:51:03 pm »
A single R and a single C makes a very poor filter. it rolls off at only 6dB (half the level) for each octave (10 times the frequency). Use an opamp or a few to make a multi-order active filter.
Offline Wimberleytech
Re: LPF question
« Reply #5 on: July 15, 2018, 04:25:36 pm »
I know you meant "octave (two times frequency)"
