Hi!
I want to be able to repair (mostly) audio gear (music stuff, amps, effects units, mixers etc). I have a low-level qualification in electronics and have managed to repair stuff before with help from others and schematics etc. However, my knowledge falls short of being able to look at a schematic and work out for myself what kind of voltage / signal I should be getting at various points (assuming there’s no test point data) - mainly because I only have a vague idea of what I’m looking at. If I don’t have a schematic then I’m stuffed beyond testing for blown fuses, bad joints and obvious things like burnt out components.
How do I go about getting the knowledge I need to be able to fault-find circuits, specifically with repairs in mind ? Is it different, in a practical sense, from the standard electronics studying of learning all the theory etc (I don’t mind doing that if that’s what it takes), but if I don’t really need to know Horowitz & Hill inside out just to pin down a knackered diode in an effects pedal, then all the better.
I’ve had a look at the ‘learning resources’ bit but that’s rather overwhelming and knowing which to pick is difficult. I’ve read Michael Geier’s “Home to diagnose and fix everything electronic” and I’m two-thirds through Forest Mims’ “Getting Started in Electronics”.
I’ve got a bit of gear (Hakko iron, 20MHz Scope, DMM, component analyser etc), but just lack the knowledge to property fault-find - especially if I don’t have a service manual spoon-feeding me.
Thanks in advance folks
