Author Topic: SMD Germanium diodes?  (Read 5135 times)
Offline awallinTopic starter
« on: November 10, 2015, 05:32:04 am »
These RF-detection/AM-demodulation circuits use Germanium diodes (because of their low forward voltage drop I guess)
http://electronics.stackexchange.com/questions/78530/how-can-i-tell-if-an-rf-transmitter-is-transmitting
1N270
1N34A
All google finds me is through-hole Ge diodes? Does anyone make SMD Ge diodes?
Thanks!
Offline Vgkid
Re: SMD Germanium diodes?
« Reply #1 on: November 10, 2015, 05:39:23 am »
Germanium diodes were obsolete for a long time, schottkey diodes offer a low voltage drop, and are in smd package, and also in T0- cased high power varients as well.
Offline Teledog
« Reply #2 on: November 10, 2015, 08:44:33 am »
Does Germanium leak as much current as the Schottky?
Just askin'
Offline coppice
« Reply #3 on: November 10, 2015, 08:50:35 am »
Just askin'
I don't know any Schottky diodes which are as low as 0.2V forward biased that leak as little as a germanium diode at room temperature. I'm not sure about when they are warmed up. However, your wallet will leak a lot less buying the Schottky diode.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: November 10, 2015, 01:16:13 pm »
I think they're pretty close, as far as Vf and Ir.  But the schottky will work to higher temperatures, and has no recovery time.
Back diodes are also available, which have even less Vf (which is actually Vr, because they're actually a marginal kind of tunnel diode), and are usable for very small signals.
Seven Transistor Labs, LLC
Offline free_electron
    • SiliconValleyGarage
« Reply #5 on: November 10, 2015, 01:37:48 pm »
Simp,y apply a dc bias.
