> Rising the current from 0.1A to 2-3A drops the output voltage with about 1 volt, regardless of what position the CC pot is
That's not how these should be behaving. What resistance is the current pot? See my last note on the list below, perhaps the installed the wrong size pot. Also check your input voltage when this problem occurs (you might have eg bad wires).
I've used these modules for years as one of my main bench power supplies. I replace the V and I pots with external ones, then add a voltage readout.
Problems I've had:
- Each board has behaved differently. There are some subtle differences between board versions even though they look mostly the same.
- They're delicate, do something wrong and the LTC3780 blows
- Behaviour when the CC and CV knobs are turned down. My last one had a min output of 0.8V. The current one shuts off to 0V out until you turn the current pot up a bit (to a few hundred mA?).
- Current pot is nonlinear (yay) except the wrong way around (very non-yay). It gives fine detail at higher currents but little detail at lower currents. I bodged a resistor in to try and counter act this a bit, it helped but isn't perfect.
- Current pot is used as a 2-terminal variable resistor, not a voltage dividing pot. This means you can't change the pot to a different value unless you also change resistors on the board. Requires some reverse-engineering. The current feedback is implemented with an opamp IIRC (the LT3780 only has a pin for voltage feedback).
