Author Topic: Used Fluke 87V with wild ACV readings  (Read 1210 times)
Offline FreebieTopic starter
« on: March 04, 2017, 12:50:31 am »
I brought a used Fluke 87V off eBay and just received it today. All ranges are ok except AC volts. The issue is if you wave the connected leads (connected to COM and Volts and nothing else) around the right side of the meter, the voltage will jump all over the place. I get readings of 2 to over 400 volts. Is this normal behavior or is the meter defective?
Re: Used Fluke 87V with wild ACV readings
« Reply #1 on: March 04, 2017, 01:39:21 am »
That's not 400 volts. It's 400 millivolts or 0.4 volts. Normal operation. You are golden.  :-+
The following users thanked this post: PowerNet
« Reply #2 on: March 04, 2017, 02:14:04 am »
It's my first Fluke and I didn't notice the range. Thanks. ;D
