Author Topic: LTSpice Error paralleled voltage sources  (Read 721 times)
Offline pharoazTopic starter
« on: October 06, 2024, 06:10:50 pm »
Hey Guys, see attached circuit, running yields the following error: Voltage source V1 and voltage source E:U1:_U6:_U1:VSS_NEW are paralleled making an over-defined circuit matrix. You will need to correct the circuit or add some series resistance.
When i run the comparator by itself (see attached) i get the correct output
When i try to run the circuit and ground all the nodes of the lm2903B i am still getting an error {Voltage source E:U2:_U6:_U1:VSS_NEW is shorted making an over-defined circuit matrix...
You will need to correct the circuit or add some series resistance}, is my wiring in correct or are the spice models i am using causing issues? Please advise, this is driving me nuts  |O
« Last Edit: October 06, 2024, 08:34:52 pm by pharoaz »
Offline Sensorcat
  • Independent Sensor Consultant
    • Sensorberatung
Re: LTSpice Error paralleled voltage sources
« Reply #1 on: October 06, 2024, 09:49:53 pm »
The first error message tells that an E-type source (voltage-controlled voltage) inside the model for U1 is parallel to V1. This must not happen, because these both determine the voltage between their nodes, but only one can. Mathematically, this is 'over-defined circuit matrix'.
The second error message tells that an E-type source (voltage-controlled voltage) inside the model for U2 is shorted. This must not happen, because shorting means zero voltage, but the voltage source value must determine the voltage, which creates the same problem as before.
The models for any IC put into a schematic are nothing else as a netlist, like, the one you create.
It is well possible that your circuit is OK, but the models of the ICs have a problem or do not work together. To find out, several iterations might be neccessary. At first, I would take the first schematic and insert a small resistor (e.g. 1 ohm) in series to V1, like LTspice suggested. Does the problem disappear? If yes, tweak the resistor value to something that does not matter in your circuit.
The following users thanked this post: pharoaz
Offline Zero999
  • 0999
« Reply #2 on: October 07, 2024, 11:06:52 am »
Which models did you use?
My guess is there's an error with the symbols. No need to draw your own, use the generic op-amp symbol built-in to LTSpice.
I downloaded the models from TI's website and they worked perfectly for me.
I suggest you try them. If you're still having issues, post the .asc file, along with any libraries and symbols. The forum allows .asc, but the other files will need to be in a zip.
Oh and please use PNG, rather than JPG for schematics. JPG is lossy and optimised for photographs, so can make lines fuzzy. PNG is lossless and compresses line drawings really well.
The following users thanked this post: Ian.M, pharoaz
« Reply #3 on: October 07, 2024, 01:58:20 pm »
Thanks for the reply! Where did you get these spice models from? I got mine from:
TLV1701 -> https://www.ti.com/product/TLV1701-Q1#design-tools-simulation
lm2903b -> https://www.ti.com/product/LM2903#design-tools-simulation
I downloaded the PSpice models for both sbom859c TLV1701 and slcj011e LM2903b; opened the .lib file in LTspice and right clicked the .SUBCKT line to create symbol (.SUBCKT LM2903B IN+ IN- Vcc GND OUT   )
« Reply #4 on: October 07, 2024, 02:23:22 pm »
Yes, while each component does work independently, when I import both your .asc files into the same schematic in ltspice i get the same error again
Offline Zero999
  • 0999
« Reply #5 on: October 07, 2024, 06:35:28 pm »
The problem appears to be that is the models share an internal node.
What I can't figure out is, with both models in the .asc file, why putting the TLV1701 in the schematic causes this error and using the LM2903B works.
EDIT1:
This is odd. I put a 1R resistor in series with the negative pin, to see what current was flowing through it, the voltage across it was 12V, which would lead to a current of 12A. I changed from a transient to DC operating point calculation to see if it made any difference but it didn't. Such a low value resistor shouldn't affect the operation of this circuit, because it's very low, compared to the other resistances in the circuit.
EDIT2:
The supply currents don't match either. Something strange is going on.
« Last Edit: October 07, 2024, 09:45:37 pm by Zero999 »
Offline Sensorcat
    • Sensorberatung
« Reply #6 on: October 07, 2024, 11:50:15 pm »
Yes, it's something strange. pharoaz, you didn't do anything wrong, you're the victim.
After downloading the models and looking into the code, I found the reason:
In TLV1701.lib, we have (line numbers):
X_U6 V+ V+_BUFFER V- V-_BUFFER Supply_Buffer (46)
which creates a subcircuit Supply_Buffer, which is defined in ...
.SUBCKT Supply_Buffer V+ V+_BUFFER V- V-_BUFFER  (83)
X_U1         V+ V- V+_BUFFER V-_BUFFER SUPPLY_BUFFER1
.ENDS
which creates another subcircuit SUPPLY_BUFFER1, which is defined in ...
.SUBCKT SUPPLY_BUFFER1 1 2 VDD_NEW VSS_NEW (246)
EVDD_NEW VDD_NEW 0 VALUE = {V(1)}
EVSS_NEW VSS_NEW 0 VALUE = {V(2)}
.ENDS
which has a reference to the node 0, the global GND!
This is OK for a model that is only meant for evaluation, but not OK for use in actual circuits. The reference to 0 means that any circuit with this model has a hidden GND connection that is not visible in the schematic and cannot be changed by anybody who does not edit models.
lm2903b.lib has similar issues, it also includes sources with references to 0. So the two models share this node, which makes them sort of collide.
I do not have the time right now to suggest a modification that resolves it, but this is definitely the reason for the problem. I wonder what they were thinking at TI to publish these models. I have used quite some other TI models, but never found something like this.
The following users thanked this post: Zero999
Offline Zero999
  • 0999
« Reply #7 on: October 08, 2024, 07:38:43 am »
.ENDS
.ENDS
Thank you for taking the time to look into it.
I did the same, but I lack a thorough knowledge of SPICE, so thought I'd wait for someone else to comment. Even though my understanding is limited, reassuringly I found the same bits of code I came to the same conclusion: a conflict between the ground nodes. This is an example of how not to write a SPICE model. Unfortunately I don't have time or the proficiency to fix this.
« Last Edit: October 08, 2024, 07:40:18 am by Zero999 »
Online magic
« Reply #8 on: October 08, 2024, 08:12:54 am »
But wait, these E elements shouldn't be a problem if they output to an internal V+_BUFFER or V-_BUFFER node of the model. This isn't the same as the externally visible VDD node, which is shorted to V1 or to GND by the OP.
And the reason they contain ground references is because their input is the {V(1)} expression, which is clearly meant to be the ground referenced voltage on subcircuit's node 1, hence the output must also be referenced to ground to be equal to the input.
If LTspice says that E:U1:_U6:_U1:VSS_NEW is shorted with the external V1, it apparently interprets
as an E element with its output on subcircuit node 1, which makes no sense :-//
Maybe it's an LTspice bug?
edit
Maybe they screwed up and swapped some nodes in their subcircuit instantiations? I.e., VSS_NEW of the inner subcircuit is actually V+ rather than V-BUFFER of the outer subcircuit?
« Last Edit: October 08, 2024, 08:28:14 am by magic »
Offline Zero999
  • 0999
« Reply #9 on: October 08, 2024, 08:19:31 am »
This isn't a fix but a work around.
I found an old model for the LM2903, which is similar to the LM2903B. I changed the pin order to match the LTSpice symbol opamp2.asy and removed (analog) which LTSpice took to be another pin.
https://ltwiki.org/files/LTspiceIV/Vendor%20List/STMicroelectronics/Standard%20Linear%20ICs/Spice/lm2903.txt
It simulates, but I've not compared it to real life. I hope it's accurate enough for the original poster.
This isn't the first time an issue about TI models has been raised here. Another person had a similar problem with the TLE2426.
https://www.eevblog.com/forum/beginners/lte2426-problem/
