Author Topic: LTspice simulation of MC34063 regulator.  (Read 14068 times)
Offline humvivzTopic starter
Re: LTspice simulation of MC34063 regulator.
« Reply #25 on: August 07, 2013, 05:13:46 pm »
Yeah!!!!! finally!
Thank you so much  :-+ :-DMM
By the way, what does it mean that MC34063 will give me feedback? Is it i have to put the probe on pin(gnd)?
Really thank you! :clap:
Offline c4757p
  • adieu
« Reply #26 on: August 07, 2013, 05:18:35 pm »
The MC34063 will back off the output when the voltage at the Cinv pin hits 1.25V. You set the output voltage by using a voltage divider chosen so that when the output is what you want, the Cinv pin sees 1.25V and the MC34063 stops increasing the voltage.
« Reply #27 on: August 07, 2013, 05:32:14 pm »
 ;D i got it!
it means Cinv pin acts as sensor,which instructs the MC34063 to continue increase the voltage or stop increase it until i gain the desired output voltage.
Can i ask one more question?
I have to design a 220uH inductor. I know i need datasheet of the iron core to determine how many turns of the coil? Anything else i should consider?
By the way, thank you  :-+
Offline c4757p
  • adieu
« Reply #28 on: August 07, 2013, 05:36:43 pm »
I'm sure there is, but magnetics really isn't my thing, hopefully someone else can answer that! I usually just throw some wire on a core until the LCR meter reads 220uH... ;D
« Reply #29 on: August 07, 2013, 05:39:35 pm »
Good idea!! ;D
Anyways, Thank you c4757p  ^^
I need to sleep now. :=\
Good bye. And wish you have a great day! Thanks again ??? |O
