Author Topic: LTspice...wish to split LT1243 output into two separate pulse streams  (Read 632 times)
Offline ocsetTopic starter
I wish to simulate a Half Bridge SMPS in LTspice, but using the LT1243 adapted to control it.
I need to split the gate drive in to two separate streams as in the attached.
Would you say D flip flop  for each stream would be best to achieve these two streams?
Re: LTspice...wish to split LT1243 output into two separate pulse streams
« Reply #1 on: December 09, 2019, 03:03:18 pm »
The attached (LTspice and schem) shows how it can be done…but I am getting an unfortunate  little spike in the waveform streams as shown.
Any better ways?
Offline unitedatoms
« Reply #2 on: December 09, 2019, 03:17:12 pm »
The spike is caused by pulse front leaking from input. You can replace your voltage TTT and SSS and both switches with 2 AND gates. Wire LT chip output to 2 inputs of 2 AND gates. Other inputs of AND gates go to Q and #Q of flip flop.
Interested in all design related projects no matter how simple, or complicated, slow going or fast, failures or successes
The following users thanked this post: ocset
