Author Topic: Lwmesh Broadcast frame Modification  (Read 758 times)
Offline PeiliTopic starter
  • Country: in
« on: August 21, 2019, 06:23:55 am »
i would like to modify the Brodcast frame at Router side which is received from End Device .. I read the developer document that "The Link Local subfield is 1 bit in length, and it may be set to one to prevent neighboring nodes from rebroadcasting a frame"..  I set my code in End Device as
                appNwkDataReq.dstAddr = 0xFFFF;
appNwkDataReq.dstEndpoint = APP_ENDPOINT;
appNwkDataReq.srcEndpoint = APP_ENDPOINT;
appNwkDataReq.options =  NWK_OPT_ENABLE_SECURITY|NWK_OPT_LINK_LOCAL;
but the broadcast frames are still broadcasting from the Routers.. How can i manage this frames.. Is my configuration is ok?
Online ataradov
    • Personal site
Re: Lwmesh Broadcast frame Modification
« Reply #1 on: August 21, 2019, 06:32:07 am »
The code is fine. Once again, why not set a debugger in the router and see why it rebroadcasts?
The check that should prevent rebroadcasts is "0 == header->nwkFcf.linkLocal" in nwkRx.c.
« Last Edit: August 21, 2019, 06:37:52 am by ataradov »
Alex
  • Country: in
« Reply #2 on: August 21, 2019, 06:39:05 am »
my Router configuration is
                           appNwkDataReq.dstAddr = 0;
                           appNwkDataReq.options = NWK_OPT_ACK_REQUEST | NWK_OPT_ENABLE_SECURITY;
is this ok?
Where to set debugger in Router code?
Online ataradov
    • Personal site
« Reply #3 on: August 21, 2019, 06:40:41 am »
This is not a "router configuration". This is just a configuration for some request. Broadcasts have nothing to do with what happens on the application level. This is totally irrelevant to anything.
Also, this is the last reply if you don't start capitalizing your sentences.
Alex
