Author Topic: LWMESH ROUTER  (Read 520 times)
Offline NeethuTopic starter
  • Country: in
LWMESH ROUTER
« on: May 26, 2019, 07:14:53 am »
hi all, i'm new to LWMESH and i would like to use LWMESH1.2.1  version.. i would like to make one coordinator and 5 router and 2 end devices.. the end devices send its Address and some sensor data to Coordinator. End device place so far from coordinator and it should route to Coordinator.. When it route the data a decision check should take at the side of router.. Where i can add that decision check at router side? i have to analyse the data come to router(sensor data value greater than some value).. then the router should take decision like the data should route or ignore... How can it be possible? Please help to solve this..
« Last Edit: May 26, 2019, 07:19:26 am by Neethu »
  • Country: in
Re: LWMESH ROUTER
« Reply #1 on: May 26, 2019, 07:16:49 am »
Now i'm able to send data from End device to Coordinator.. But can't do the decision check.. All the data from end device is receiving at the coordinator side..
« Last Edit: May 26, 2019, 07:20:15 am by Neethu »
