So you will exclude that is a resistor?
Quote from: giovesjo on May 23, 2019, 08:12:37 pmSo you will exclude that is a resistor?Not entirely. It could be a 0.2Ohm resistor, but it's unlikely.
Quote from: Zero999 on May 23, 2019, 09:40:35 pmQuote from: giovesjo on May 23, 2019, 08:12:37 pmSo you will exclude that is a resistor?Not entirely. It could be a 0.2Ohm resistor, but it's unlikely.Only if you use ferrite beads as resistors .
Quote from: Zero999 on May 23, 2019, 09:40:35 pmQuote from: giovesjo on May 23, 2019, 08:12:37 pmSo you will exclude that is a resistor?Not entirely. It could be a 0.2Ohm resistor, but it's unlikely.If it is a 200mΩ resistor it will be a current shunt(not sure(thats the only purpose for 200mΩ as i know)).I dont think current shunts will be made that small(lower power rating).I think it will be an inductor.
