I am trying to understand how the following schema works:
from
http://www.gae.ucm.es/~padilla/extrawork/magamp.htmlesp. the preamplifier part.
This is a mag card reader but I am interested in how the mag
field is used to encode information, not the reader itself.
As far as I understand, the data are encoded by same polarity
magnetic dipoles being interfaced on the card stripes, creating
a force (since they are the same polarity), thus allowing to encode
data.
Regarding the schema, what I guess is that by creating a force,
the characteristics of the self are modified (by the flux created by
the same polarity dipole interface on the stripe). I guess that this is
the reactance of the self that is modified, but I do not know much
about that, could you point me to some links about that? If I am
right, the equivalent resistance C1 L1 has to be computed, then
the equivalent resistance with R2, then we have the base voltage
for the transistor base when mag field is present, and when mag
field is not present. Is my understanding correct?
I noted there is no value for the self in the schema, but it is not
a problem, I am interested in "how" such a schema should be
interpreted, in order to make mine later. If you have any links
with the related maths, from a practical point of view...
Thanks for helping,
Fabien.
