Author Topic: Magnetic inductors....What are they called?  (Read 2634 times)
Offline SeekonkTopic starter
« on: November 03, 2014, 09:06:46 pm »
I was taking some components out of a TV before I recycled it. It was a CRT type, one of the last runs for these.  I noticed screws and other things sticking to these.  These radial open bobbin flyback inductors were wound on a fairly strong magnet.  Everyone knows that an inductor becomes just a resistor once it saturates.  Starting with a core that is magnetized should allow you to store twice the energy.  That is, if you don't drmagnetize the core in the process.  Anyway, this is the first time I have seen these in a product and I have been traring things apart for more than 40 years.  Went looking for an app note for an interesting read.  None of the search terms  I used came up with anything.  Any idea on what these are called?
Offline Rufus
Re: Magnetic inductors....What are they called?
« Reply #1 on: November 03, 2014, 11:52:34 pm »
"Biased Inductor" or " Magnetically biased inductor"
Hits a few patents and papers. Doesn't seem to hit any products you can buy.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: November 04, 2014, 12:02:11 am »
It's either for extending the useful range of a flyback inductor (does the expense of a magnet justify the added range?), or for controlling the nonlinearity in a saturating application (more likely -- deflection circuitry).
Seven Transistor Labs, LLC
Offline megajocke
« Reply #3 on: November 07, 2014, 10:18:58 pm »
Sounds like the horizontal linearity correction coil:
http://www.repairfaq.org/sam/deflfaq.htm#dshlc
