Hi guys
I've designed and build an adjustable dummy load, kind of what Dave showed in one of the blogs..
I use some other components, and included a PIC16F877a and a 16x2 lcd, for measurement.
I found that when the circuit is powered form a non-earthed power supply, the digital part doesn't work, and sometimes erases the microcontroller (all the voltages looks fine?!). But when powered from a 9v battery, or an earthed supply, it works fine.
I have no idea why!
I've tried both a standard 9v adapter, and my adjustable power supply, neither works.
We don't have earthed wall outlets! But I tried burying a pipe in the garden, with a wire going to the negative terminal on my power supply, and it worked fine
.. ( yea, i actually did that, was desperate
I'm not sure how the DC relates to the mains earth, when it's been through a transformer, and been rectified ?
Can anyone explain why this is happening ? And how to avoid the problem, so I CAN use a non-earthed power source ?
I'm sure it's just a basic thing I don't know about
I'm still a beginner in electronics
I did add caps at the Vdd/Vss of the micro, at the power input, and after the 5v regulator.
I get the same problem with almost any MCUprojects, I tried breadboarding a few afterwards.
Do anybody have the same problem ?
More info available, if needed
-Mads
