Author Topic: Mains voltage with non zero DC, how bad is it ?  (Read 13417 times)
Offline BravoV
  • +++ ATH1
« on: February 26, 2014, 04:44:52 am »
How bad is it if your mains has DC volt ? When measured with DMM that can show AC + DC voltages separately.
At which level it will become bad thing for common house hold electronic appliances ? CMIIW, I'm thinking those transformers in power supply must be heating up unnecessarily, right ? Anything else ?
What is causing it if this really happened ? or its very unlikely at residential area ?
Its just my curiosity since my mains shows zero DC all the time.
Update :
Posted a short video on a hair dryer that made a DC offset in AC mains line at post #37 -> Here.
« Last Edit: March 03, 2014, 06:44:06 am by BravoV »
Offline HackedFridgeMagnet
Re: Mains voltage with non zero DC, how bad is it ?
« Reply #1 on: February 26, 2014, 05:13:43 am »
Funny thing is that DC stands for Direct Current.
So DC volts obviously a common term, is Direct Current Volts?
I'll take a stab at this.
The local substation can't really supply DC volts as the transformer supplies an emf proportional to the change of flux. So the voltage is naturally is AC at the point of supply.
But with non linear loads and especially half wave rectifiers loading this (however insignificantly) then current at the point of use can have a dc component.
Therefore due to imperfect transmission lines your point of use voltage will not necessarily be purely AC.
I doubt it would be in anyway significant or easily measurable though from a decent supply authority.
Offline peter.mitchell
« Reply #2 on: February 26, 2014, 05:50:02 am »
If the DC offset did exist, an SMPS would not suffer at all; potentially it would be even more efficient because it would be easier to achieve a power factor closer to 1.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: February 26, 2014, 06:32:35 am »
You couldn't get a DC bias on a normal mains supply because it's fed by a sub-station transformer, and transformers don't pass DC.
Anyone/anything trying to force a DC bias onto the normal mains supply by other means would be faced with an extremely low DC impedance to overcome - sub-station transformer along with all the other user transformers on the same supply/phase.
Though uncommon these days, half-wave rectified loads draw DC.  Perhaps a lot of low quality LED lights?
Quite possible one could also see mere residual measurement error in the instrument.  Averaging out 120 or 240V AC to get just a few volts leftover is no small feat.
Seven Transistor Labs, LLC
Offline BravoV
  • +++ ATH1
« Reply #4 on: February 26, 2014, 07:51:41 am »
Thanks for all replies  :-+ , learned something new today, even though its probably a very basic 101 of electricity.  :P
Offline The Electrician
« Reply #5 on: February 26, 2014, 01:50:26 pm »
You can't just connect your voltmeter to mains and then select DC on some low range; the meter will be overloaded by the AC component.
Have a look at this rather long thread.  Toward the end I discuss the possibility of DC on the mains in your house:
http://forum.allaboutcircuits.com/showthread.php?t=37358
« Reply #6 on: February 26, 2014, 07:02:07 pm »
Dc on the mains was a problem years ago when colour TV sets were being introduced. Phillips made the G11, which used a half wave switchmode power supply ( a thyristor connected in series with the mains and controlled by the HT voltage, it would typically draw a 11A pulse every second mains cycle) that caused quite a few distribution transformers to catch fire from the high DC current saturating the core, as it had never been designed to have a 100A or so DC current flow ( as these were all UK sets they were all wired correctly so all the current pulses added up) in addition to the regular load, and the core material ran out of it's linear region and saturated. Later transformers were designed with larger cores and a small air gap distributed around the core to reduce saturation. That is why half wave rectifier power supplies are outlawed in most countries for any load over 10W or so.
Offline kizzap
« Reply #7 on: February 27, 2014, 01:17:38 am »
I am curious as to how you were measuring the DC voltage, as in what it was relative to. If it was ground, aka a ground pike plugged into ground, then yes it can be a bad thing. There is a reason that Neutral is tied to Earth in the power distribution box.
<MatCat> The thing with aircraft is murphy loves to hang out with them
<Baljem> hey, you're the one who apparently pronounces FPGA 'fuhpugger'
Offline BravoV
  • +++ ATH1
« Reply #8 on: February 27, 2014, 02:01:09 am »
Don't worry, I used Fluke 287 which is safe to use for such purpose, see my reply to kizzap below.
Thank you, great info  :-+, it may take a while for me to digest it all though.  :-[
But the experiment with hair dryer is interesting, I will try it and report back.
The half wave rectifier, is that a direct rectifying the mains using high voltage rectifier without using a transformer ?
Are there other common house hold electronics that you aware of that can caused that DC flow ? Even they're banned now.
I used Fluke 287, it can display something like this below, but in my experiences, I never spotted any DC voltage, as they're always zero, while the AC voltage is spot on.
Example from Fluke manual, these are just the variations on how to display AC and DC at the Fluke 287/9 display.
« Reply #9 on: February 27, 2014, 02:09:24 am »
Hair dryers use the rectifier in series with the heating element to get the low or medium power setting.  No transformer involved, just a rectifier diode in series with the heater.
I don't know of any other common household devices that use a rectifier like that.
For measuring the DC on the mains you need to use a low pass filter consisting of a resistor and capacitor as I explained in that long thread.  The DC you're trying to measure will be in the millivolts and the 120 VAC will be applied to the DC range of the meter as well as the DC you're trying to measure.  It won't hurt the meter but it will overload the sensitive DC range and give an erroneous reading.
Offline BravoV
  • +++ ATH1
« Reply #10 on: February 27, 2014, 03:01:42 am »
My Fluke 287 when set to AC and DC measurement, since my mains is 220 V, the voltage range for both AC and DC will use the 500 Volt range, as above example picture that the Auto Range was set at 500 V.
At this range, the DC part has 10 mili Volt resolution, is this enough for this "hair dryer" test ?  :P
As I mentioned, when measuring in this mode at mains, usually the DC part is flickering at the least significant digit at 0.01 Volt.
Offline AlfBaz
« Reply #11 on: February 27, 2014, 03:23:40 am »
Assuming a fairly symmetrical sine wave from mains wouldn't measuring peak min/max values give you some idea of the dc content?
I don't know anything about the fluke 287 but the 87 has peak min/max so good chance the 287 does also
Offline c4757p
  • adieu
« Reply #12 on: February 27, 2014, 03:30:42 am »
And a spherical cow?
Offline BravoV
  • +++ ATH1
« Reply #13 on: February 27, 2014, 03:38:01 am »
Yes, it has peak min, max and average, apart from the live one that keeps running.
How to read if there is a DC content ? An unbalanced voltages between avg-min vs max-avg ?
« Last Edit: February 27, 2014, 03:42:05 am by BravoV »
Offline AlfBaz
« Reply #14 on: February 27, 2014, 04:08:36 am »
My need for an emoticon with shit flying over a head is growing by the day
Offline AlfBaz
« Reply #15 on: February 27, 2014, 04:11:49 am »
Given c4757p's response it looks like I may be completely wrong but if there is and dc content it's effect will be to shift the ac above or below 0V. Using the peak min/max readings might show this "inbalance"
« Reply #16 on: February 27, 2014, 05:18:35 am »
The point is BravoV is trying to force the voltage sine wave into asymmetry with the hair dryer, and then to measure the resultant DC volts, so why should he assume symmetry?
Read the electricians thread on all about circuits, it reveals all.
Sounds like a good one.
« Reply #17 on: February 27, 2014, 09:54:59 am »
It would be easy enough to use a 100k resistor and a 1 uF film capacitor to make a simple low pass filter.  Then you can measure the voltage across the capacitor with the meter set to a low DC volts range, and compare with what you get with the 500 volt AC plus DC measurement.
Online Zero999
  • 0999
« Reply #18 on: February 27, 2014, 11:08:42 pm »
Yes, I've seen that before, although if the hair driers were made with 50% of them with one polarity and 50% with the other, it will average out.
« Reply #19 on: February 27, 2014, 11:16:15 pm »
Only if several of each kind are in use in a given residence.  How often is more than one used at a time in a home?
Offline AlfBaz
« Reply #20 on: February 27, 2014, 11:20:59 pm »
Girls Dorm on a Friday night?
Offline BravoV
  • +++ ATH1
« Reply #21 on: February 28, 2014, 02:08:09 am »
Thanks, will try this when I get home this weekend and share the result here.
Hopefully the SWMBO's hair dryer is the half wave rectifier type.
Offline CaptnYellowShirt
  • Scooty Puff Jr.
« Reply #22 on: February 28, 2014, 02:27:31 pm »
Do you see a potential between Neutral  and Ground? If so, how much?
Offline c4757p
  • adieu
« Reply #23 on: February 28, 2014, 02:39:52 pm »
Just saying - if you want to measure millivolts on top of 170/340 peak, by assuming symmetry, you're going to need a very symmetric sine wave. Like, within 300-600ppm or so. And mains is usually very sloppy.
Online Zero999
  • 0999
« Reply #24 on: March 01, 2014, 07:56:18 pm »
I don't know about where you live but where I am, a distribution transformer will power a whole street or housing estate so it's pretty likely more than one hair dryer will be used simultaneously.
« Reply #25 on: March 01, 2014, 08:30:49 pm »
What I mean by distribution transformer is the pole mounted "pole pig":
You're probably thinking of the larger type found in substations:
Online Zero999
  • 0999
« Reply #26 on: March 01, 2014, 09:31:22 pm »
Lol, I've never heard the term pole pig before. Where I live there aren't any transformers on poles. There's a substation at the end of the road which powers half the village.
Offline sync
« Reply #27 on: March 01, 2014, 09:32:18 pm »
These are almost non-existent here in Germany. One of our distribution transformer supply up to a few hundreds domestic homes. It outputs 400/230V tree-phase which is directly distributed to the houses. And we are using underground cables. A typical distribution transformer looks like this.
« Reply #28 on: March 01, 2014, 09:49:52 pm »
This situation cries out for some measurements.  You guys could have many hair dryers on at the same time in the morning when people are getting ready for work.  Build the low pass filter I described and see how much DC you observe.
On my street, no more than 3 houses are served by one pole pig, so the DC from one house where a hair dryer is used on half power isn't communicated to more than 2 other houses.  You might have many hair dryers on at the same time, all on the same circuit!
Offline sync
« Reply #29 on: March 01, 2014, 10:20:05 pm »
Our plugs are non-polarized. So the hairdryers cancel each other out statistically. :)
I made the test. I measured the DC of an outlet directly with a mulltimeter (1000V range, 100 PLC integration time). Without the hairdryer the DC level was <30mV. With the hairdryer set to half power (600W) it was ~1V on the outlet of the dryer and ~0.4V on an outlet connected to a different circuit breaker but on the same phase.
« Reply #30 on: March 01, 2014, 11:45:12 pm »
That's probably enough to cause the saturation effects (in an audio amplifier with a toroidal power transformer) reported by golden ears audiophiles.  :-+
Offline johansen
« Reply #31 on: March 02, 2014, 12:39:57 am »
meh, tell the folks that can hear the bad mains power to increase the PSRR of their tube amps.. oh, wait, my bad. what's PSRR?  :-DD
anyhow, yes, 1 volt of dc is enough to blow up your mains.
I stick weld with a variety of nonstandard voltages and currents.
running various rods say, 7018 on ac, when they are meant for dc, sometimes you can hear the transformer saturate because the arc is pulling more dc amps than ac on various polarities. i've noticed this with other rods as well. so sometimes i switch to dc, because that rectifying action reduces the power available at the arc.
Offline sync
« Reply #32 on: March 02, 2014, 01:38:32 am »
Damned! How can I protect my amplifier from this evil DC? Does a blocking capacitor works? How big must it for 1.5kW? >:D And how can I make the noisy hairdryer quieter so I can hear these bad saturation effects?
Seriously, I wounder how much DC a transformer tolerates before it goes into saturation.
Offline johansen
« Reply #33 on: March 02, 2014, 04:25:19 am »
three diodes can be configured to deliver .3v drop in one direction and .6v drop in the other (use 30 amp Schottkys) for testing this yourself.
switch to silicon diodes to get a 1v dc bias, and a D cell battery to get 1.5V, etc.
Offline ampdoctor
« Reply #34 on: March 02, 2014, 05:04:56 am »
Everybody is talking about all kinds of odd possibilities but I've yet to see any mention of ghost or phantom voltage.
  • Scooty Puff Jr.
« Reply #35 on: March 02, 2014, 07:14:33 pm »
How about *just* ghosts or phantoms?
Offline BravoV
  • +++ ATH1
« Reply #36 on: March 03, 2014, 06:35:29 am »
Decided to take a short video on the test, apologize for the amateur video quality.  :P
Few notes on the measurements :
- Hairdryer is Philips 1600 watts with 3 selections for the heat & air speed, plugged at cheap watt meter at the front for monitoring the power consumptions.
- Fluke 287 was set using DC over AC mode, while 87V was set at DC Voltage mode.
- Both dmms range were set manually at 500V for the 287 and 600V for the 87V.
So the hair dryer vs DC results :
Off -> DC = 0 Volt
Low @50 watt -> DC = 1.2 Volt  ???
Mid @650 watt -> DC = 0.6 Volt
High @1300 watt -> DC = 0 Volt
@The Electrician, I can't find my motor start capacitor  :-\, probably buried somewhere in the pile of component junks, and I don't have any other high volt cap available, so no simple RC LPF measurement yet as you've suggested, sorry.  :-//
Comments are welcome.
Attached below photos with the measurements results as above video for better details.
« Last Edit: March 03, 2014, 10:12:29 am by BravoV »
Offline BravoV
  • +++ ATH1
« Reply #37 on: March 04, 2014, 06:04:29 am »
Is possible that I might interpreted wrongly on my above test that the DC result is a phantom voltage ?  ???
Offline BravoV
  • +++ ATH1
« Reply #38 on: March 04, 2014, 07:07:00 am »
Sorry, missed this question, Neutral to Ground voltage is about <= 1 Volt AC.
Offline johansen
« Reply #39 on: March 04, 2014, 07:08:25 am »
you should be able to measure some dc between neutral and ground during the load test, due to the resistance of the neutral line.
the remainder of the dc would be formed by the resistance of the hot line and the incoming supply.
Offline BravoV
  • +++ ATH1
« Reply #40 on: March 05, 2014, 06:00:31 am »
The DC measurements between Live (L) and Neutral (N) vs Ground (G) with negative black probe was attached permanently at Ground line :
Off  -> L to G = -0.1 V  and  N to G = 0 volt
Low @50 watt -> L to G  =  0.6 V and N to G = -0.6 volt
Mid @650 watt -> L to G  =  -0.4 V and N to G = -0.2 volt
High @1300 watt -> L to G  = -0.1 V and N to G = 0 volt
What does this mean ? :-//
Offline johansen
« Reply #41 on: March 05, 2014, 07:21:03 am »
it means i greatly suspect the .6v reading for the low setting.
the medium setting shows that a third of the dc voltage is across the resistance of the neutral line, the other third across the hot line, and the other third appearing at the breaker box.
the 1300 watt datapoint of .1 volts dc line to ground is also suspect.
Offline BravoV
  • +++ ATH1
« Reply #42 on: March 05, 2014, 09:57:07 am »
johansen, thanks for reply, but honestly, I still don't get it.  :-[
